Hi Phil,
The Crompton & Parkinson 1/4 hp single phase motor fitted to my Myford ML7 used to do the same.
In my case, (and because the motor was uncovered), metal swarf was finding its way into the electrics via the motor’s ventilation holes. The shorting was not sufficient to blow fuses or trip the leaky earth switch, but it certainly made a loud popping noise when it happened. There was also a sizzling noise (mechanical not electrical), which once again was swarf. This time the swarf was rubbing against the rotor. I would guess that steel swarf was being attracted to various parts as a result of the magnetic field(s).
I cured this problem by applying metal fly wire (readily available in Australia), over the vents.
The original lathe owner had a `wonderful’ way of starting the lathe. When I bought it from his widow, the centrifugal switch inside the motor was stuck in the `open’ position. It was clear that the owner (who had removed the belt guard), was using the large pulley to spin-start the lathe motor.
Once the motor was stripped down, it took very little to free the switch.
Both problems were duly fixed and never returned.
I no longer have my workshop, but fitting a 3PH motor seems to be a very common improvement. See other postings.
Best regards to all,
Sam
Edited By Sam Stones on 01/03/2011 21:26:52
