Have a problem when milling
Stock i5/8 x 3/4 is in the vice overhanging by 3in
The vice is as near square ( 2xDTI ordered to get it 100£ in future) as makes no difference with what i need to do
First take a cut on thr top side ( the 3/4)
Then i want to get the 5/8 sides down to 0.531.
I mill the back part by taking about 20thous off
Then get the cutter to the front one to get it to width, and here is where the problem sides
Checking that the front is still 'parallel' to the rear i fine that over a cut of 2 inches it tapers .007 over the length from left to right
I am not taking massive cuts 10 thous max going do as i near reqd width
I would have thought the irrrsipective of the angle of the vice jaws the cuts should be parallel. There is no play in either the bed or the quill or the vice bolt
Amy ideas as to why it is doing it? perhaps smaller cuts?
