which parting tool
which parting tool
Home Forums Beginners questions which parting tool
  • #386424
    Martin Newbold
      @martinnewbold
      Is it better to have one of these to fit my tool postpost https://www.ebay.co.uk/itm/New-Myford-quickchange-toolpost-holders-vee-parting-extended-Direct-from-Myford/142945943331 or would it be better to buy a seperate or something like that goes into the tool holder. I am thinking first one for rigidity . an i get cobalt blades for this ?
      this https://www.ebay.co.uk/itm/RDG-TOOLS-12MM-PRO-LATHE-PARTING-SYSTEM-WITH-COBALT-BLADE-BOXFORD-MYFORD-TOOLS/351654553282
      Edited By Martin Newbold on 19/12/2018 10:50:19
      #9451
      Martin Newbold
        @martinnewbold
        #386428
        Vic
          @vic
          The best I’ve used is the T shaped blade type from Chronos.
          I use the 1/2” wide blade type on my 8 x 14 lathe.
          #386444
          Ray Creighton
            @raycreighton18996
            Hi,
            Check out: eccentricengineering.com.au (there is a UK agent) , inverted parting tool, Great design as all the shavings drop out to aid clean parting
            HTH
            Harry Wilkes
              @harrywilkes58467
              I'll second the inverted parting tool always struggled with parting off on my super 7 until I purchased the inverted parting tool and fitted it into my rear tool post now I can part off without any trouble.
              H
              Posted by Ray Creighton on 19/12/2018 12:17:06:
              Hi,
              HTH
                I used one of the type in your first like for quite a while but seldom use it now, I use one of the blade type holders that take a 2mm wide insert. Seems to push the swarf up out of the kerf OK
                #386449
                John Rudd
                  @johnrudd16576
                  Parting
                  I use one of the blade types  with 3mm tips
                  Edited By John Rudd on 19/12/2018 12:56:36
                  #386475
                  mark costello 1
                    @markcostello1
                    Well, I just started a thread in the General section showing My solution. Combines the best ideas of both.
                    #386480
                    Howard Lewis
                      @howardlewis46836
                      Made up a back toolpost when I had a ML7.
                      One of the first jobs when I bought my new lathe was to make a back toolpost for it. Still using the secondhand HSS blade that I was given when i bought the used ML7 nearly 30 years ago. Mounted inverted, it rarely shows any sign of digging in. Easy to sharpen, and cheap to run.
                      Wish that i could say the same for using replaceable tip parting tools, inn the front toolpost! A very expensive tool to use!
