What material is it
What material is it
Home › Forums › The Tea Room › What material is it
  • #385838
    martin perman 1
      @martinperman1
      Gentlemen,
      I am machining a brass like material but I'm certain it isnt brass because when I've machined brass in the past it comes off in small needle like swarf where as this comes off in streams of swarf like steel and anything larger than a 0.5mm the lathe groans greatly,
      Any Ideas please.
      Martin P
      #35341
      martin perman 1
        @martinperman1
        #385840
        daveb
          @daveb17630
          There are different grades of brass, some alloys are hard, some are ductile. It could be bronze. There are different grades of bronze. Sometimes difficult to tell one from the other. Daveb
          #385898
          colin hawes
            @colinhawes85982
            Aluminium bronze, horrible stuff to drill. Colin
            #385903
            I.M. OUTAHERE
              @i-m-outahere
              I know the brass they make amunition out of is gummy stuff so you may have a grade of brass that is designed for forming .
              #385907
              JohnF
                @johnf59703
                Plus 1 for Aluminium Bronze machined a lot of this in the past and as Colin also say’s it’s difficult to drill, grabs the drill if you are not careful. One other point don’t use it as a bearing material (bushes) it is totally unsuitable— I know this from experience with a small engine I was repairing many years ago.
                Edited By JohnF on 16/12/2018 10:22:30
                #385909
                martin perman 1
                  @martinperman1
                  Thanks gentlemen, I'm making four 75mm dia rollers for a mates butter churn, to support the drum and decorative only.
                  Its a bugger to cut on my band saw also.
                  Martin P
                  #385916
                  vintage engineer
                    @vintageengineer
                    Ali-bronze! It's s**t!
                    Edited By Neil Wyatt on 16/12/2018 13:05:19
                    #385924
                    not done it yet
                      @notdoneityet
                      Look up ‘copper alloys’ on Wiki and take your pick!
                      #385926
                      colin brannigan
                        @colinbrannigan54160
                        Ali bronze is worse than s**t!!
                        Edited By Neil Wyatt on 16/12/2018 13:05:29
                        #385949
                        I.M. OUTAHERE
                          @i-m-outahere
                          What tool geometry are you using ?
                          #385953
                          Nicholas Farr
                            @nicholasfarr14254
                            Posted by vintage engineer on 16/12/2018 10:54:10:
                            Hi, sorry, but I beg to differ.
                            Regards Nick.
                            Edited By Neil Wyatt on 16/12/2018 13:05:38
                            #385958
                              Mind yer language please folks!
                              The only sticky brown stuff on this forum comes from trees
                              martin perman 1
                                @martinperman1
                                Posted by colin hawes on 16/12/2018 09:56:47:
                                I would beg to differ, I've just given up trying to drill a hole through a slice I cut off, its wearing out brand new drills without hardly making a cut, the drill just polishes the metal.
                                My mate is going to have to find a different lump of brass or go back to plan A and use steel. I've just done a test on a lump of brass I have on my saw, the un machinable lump 95mm dia took three hours to cut a slice, my piece is 65mm and the saw was half way through in no time at all with the same blade.
                                Martin P
                                #385968
                                not done it yet
                                  @notdoneityet
                                  I hope it is not difficult. I had a casting made by my local foundry some years ago. It turned very nicely and I have about 40 small holes to drill very accurately (to make an exact copy of an original part) and some of them will need tapping and countersinking.
                                  #385984
                                  Alan Johnson 7
                                    @alanjohnson7
                                    Have you tested your "brass" with a magnet? Some bonze has an iron content, and therefore magnetic. It may narrow your search.
                                    You could do the Archimedes Test…… Place sample in water, measure displacement, and weigh sample. Again it could narrow your search.
                                    #385988
                                    Alan Johnson 7
                                      @alanjohnson7
                                      I should have added.. Archimedes Test will yield Kg per cubic metre. Known bronze and brass list this.
                                      #385989
                                      colin brannigan
                                        Sorry Neil
                                        #385999
                                        not done it yet
                                          @notdoneityet
                                          Posted by Alan Johnson 7 on 16/12/2018 16:53:11:
                                          I would not expect a simple ‘Archimedes test’ would do more than reject the extremes of density, particularly if other elements are present.
                                          Might just as well weigh in air and water to calculate, unless of very uniform and measurable dimensions when the volume could be accurately assesed. For decently accurate results, I would be using the turnings/chips and an SG bottle, along with an assay balance…
                                          Possibly a phosphor bronze?
                                          #386013
                                            Aluminium and copper make some interesting alloys.
                                            Small amount of copper in aluminium is pretty much duralumin.
                                            Small amount of aluminium in copper is aluminium bronze, but the more ally added, the harder it gets. By around 50:50 you get a grey alloy that shatters if you hit it with a hammer.
                                            Hard to machine aluminium bronzes may have more aluminium than intended.
                                            P.S. at our astro club Christmas quiz a question was 'what metals make Bronze'. It was tempting to answer copper and anything other than zinc, except when it's got zinc in it…
                                            #386042
                                            JohnF
                                              @johnf59703
                                              Martin, as Neil says aluminium bronze comes in different alloys, it is difficult to machine but certainly not impossible and it is also highly corrosion resistant. The components I was machining many years ago were for submarine seawater services [corrosion resistant ] and were for want of a better description "very large plumbing fittings" pipe diameters of 6 to 12 inches, large flange's on castings to be machined then drilled and tapped or drilled and spot faced. The factory also produced other components from bar stock.
                                              Sharp HSS tools are the order of the day and increase the top rake a little, for drilling, thin the point to ease the process and grind VERY slightly offset so it cuts slightly oversize — do not alter the flute rake as for brass. The best cutting medium is suds, it can generate a lot of heat when cutting. Your tools must be sharp !
                                              I have machined this material successfully on my Myford with correctly ground tools etc.
                                              Hopper
                                                @hopper
                                                Posted by martin perman on 16/12/2018 13:47:24:
                                                … I've just given up trying to drill a hole through a slice I cut off, its wearing out brand new drills without hardly making a cut, the drill just polishes the metal.
                                                Did you try slowing the spindle speed way down? And drilling a small pilot hole first?
                                                If so, you may need to anneal the bronze before trying to cut or machine it.
                                                Edited By Hopper on 17/12/2018 03:03:50
                                                #386059
                                                martin perman 1
                                                  @martinperman1
                                                  Gentlemen,
                                                  I'm doing this as a favour for a friend and its costing me money, three worn out and broken bandsaw blades, and time trying to machine, for me, the impossible. I dont have or use HSS tooling.
                                                  I've now asked my friend to source some different material.
                                                  Martin P
                                                  #386062
                                                  Brian H
                                                    @brianh50089
                                                    Another way to identify it is to try and silver solder it. If it's ali-bronze, it won't.
                                                    Don't ask me how I know!
                                                    #386066
                                                    Nicholas Farr
                                                      @nicholasfarr14254
                                                      Posted by Brian H on 17/12/2018 08:33:11:
                                                      Hi Brian, I don't quite agree with you, below is a photo of a Ali-Bronze block Silver soldered to a Brass plate, that I did about 30 years ago. I don't know the grade of the Ali-Bronze, but I do know it is Ali-Bronze, it was hacksawed, filed and drilled from a worn out Ali-Bronze nut.
                                                      Regards Nick.
                                                      Edited By Nicholas Farr on 17/12/2018 09:26:53
