It wasn't today, it was yesterday, but this is an object lesson in leaving well alone.
I bought a bandsaw from my local secondhand shop, did the insulation test and earth continuity, plugged it in, happy days.
The main lead had pulled through its cable gland into the motor terminal box, so yesterday I thought I'd while away 15 minutes putting that right. Simple enough.
Until I took the cover off the terminal box, and realised that the black bits in the bottom were broken insulation off the motor leads. Oh dear.
Can't leave that alone, so here's what I found when I took the end cover off the motor:
Not the best photo ever, sorry about that. The green lead RHS of picture is one of the main winding leads, the two once-upon-a-time white ones are the starter winding on a 6 pole single phase capacitor run motor of about 3/4 HP. These wires are the original tails connected to the motor windings, and look as though they have been overheated though I can't explain why there is no evidence of damage to the windings themselves, and no "burnt" smell. The insulation is brittle and cooked, and the wire itself is tarnished and oxidised.
I cut the damage out, grafted some PTFE insulated wire in with heat shrink sleeving and threw it all back together. Not the best job ever, but better than it was.
I could have made a better job if I knew how to withdraw the stator lamination stack from the motor outer housing. Any clues anyone? The only thing I can find on the internet assumes the windings are already toast, and you can pull the whole thing to pieces by brutality. In my case there seemed to be nothing wrong with the windings and I'm reluctant to get it rewound when it still works.
So it runs, takes a sensible looking load current, insulation at 500V is 85 megohms. I've put it back together and it'll do.
Rgds to all
Simon
