watchmakers lathe plans
Home › Forums › General Questions › watchmakers lathe plans
  • #23142
    AussiePete
      @aussiepete
      #143490
      AussiePete
        @aussiepete
        Hi people I'm new here and already need help….
        I was contemplating building a watchmakers lathe as I need some non engine projects and while searching for a possible lead I found an article which mentions such a project in Model Engineer August 1965 but cant find the plans (plan WE13) anywhere. Any help would be appreciated.
        Pete
        #143496
          Available from MyHobby Store
          It did use a few iron castings and I don't think they are available now but you could cut from solid or fabricate
          J
          Edited By JasonB on 11/02/2014 10:51:13
          #143502
            Pete,
            Welcome aboard !!
            If you are thinking of a traditional watchmaker's lathe [either Geneva Pattern, or Webster Whitcomb] then you have a tricky job ahead. The "proper" bearings are glass-hard, steel-on-steel, with a double cone shape.
            If you just want to build a small lathe; have a look at the excellent book by L.C. Mason.
            Edit: added hyperlink.
            Edited By Michael Gilligan on 11/02/2014 11:32:32
            #143508
            David Clark 13
              @davidclark13
              Hi There
              WE13 is still available from MyHobbyStore.
              Two sheets but I don't know the price.
              regards David
              #143511
                Try clicking my link above for the price DCwink 2
                #143512
                John McNamara
                  @johnmcnamara74883
                  G'day AussiePete
                  Good to see ya………and Welcom aboard.
                  If you are building a small lathe look out for a small granite or cast iron surface plate also a dial indicator and stand will help to check for parallelism and flatness. You should be able to scrape the bed to within a tenth or two.
                  john
                  Melbourne OZ
                  Edited By John McNamara on 11/02/2014 12:19:48
                  #143523
                  AussiePete
                    @aussiepete
                    Thanks for the quick responses guys. Jason thanks for the link I spread myself thin lol
                    Thanks John from Sth Oz hope the fires aren't too close to you. Yes I have those bits so looking forward to the project though not in 40+C days we are having for the last month…should drop to mid 30's by the weekend
                    Pete
                    #143552
                    Lars-G Kjellander
                      @lars-gkjellander17135
                      Hi AussiePete
                      Many years ago I was in the same situation thinking of building a small lathe. And at that time I found an article i M.E. Vol.150 No.3704 – Vol. 152 No.3730 (1983-84) – about a building project of: "A 2 5/8 in. Centre Lathe" – "A Design for Home Construction Using Stock Materials" by J. Neave. 2 5/8 in centre height, 1 1/2 in over cross slide, 9 1/2 in between centres 27in overall length, approx. 65 lbs weight.
                      I eventually ended up buying a Sherline lathe instead, much quicker, life is short and project list tooo long smiley
                      Lars
