Was in Penrith and this pulled up.
Home Forums The Tea Room Was in Penrith and this pulled up.
  • #302637
    mark smith 20
      @marksmith20
      Im not into cars really but this turned up out of the blue and found it fascinating
      .A Rolls SIlver ghost i think. Wife took photos on her phone camera. A few more photos in my albums under Rolls.
      mark smith 20
        @marksmith20
        #302638
        John Rudd
          @johnrudd16576
          Magnificent does not even come close……what a marvellous car..
          #302640
          John Stevenson 1
            @johnstevenson1
            You would have thought that with all that money involved he could have afforded a bonnet cover?
            Edited By John Stevenson on 15/06/2017 10:43:02
            #302642
            Steven Vine
              @stevenvine79904
              Posted by John Stevenson on 15/06/2017 10:42:18:
              John, that's the engine cooling system.
              Steve
              #302649
              Speedy Builder5
                @speedybuilder5
                Yep, couldn't afford the spokes for the spare wheel! Very impressive (excuse the pun) door and body pressings for the time. I note he didn't have the windscreen straps on, so perhaps not going on a long trip.
                BobH – 2CV van owner !
                #302650
                richardandtracy
                  @richardandtracy
                  Given the age & production numbers, more likely to be panel beaten I think.
                  Looks absolutely immaculate. Somewhat envious.
                  Richard – 2CV Charleston owner
                  #302666
                  Mike E.
                    @mikee-85511
                    Wow, what a jewel !
                    I remember seeing a Rolls similar to that for sale for ten thousand dollars at the Rose Bowl swap meet in California back in 1970. There was also a gull wing Mercedes for sale for fourteen thousand at the car show held on my High School's football field the same year. If one could only have speculated their future value and desirability in todays world.
                    smiley
                    #302667
                    Perko7
                      @perko7
                      Reminds me a bit of a RR 20hp tourer owned by a friend of my father. Like most RR's it could be started without using the starter. The reason given, I am told, was that when 'sir' was departing from the club, the noise of a starter motor, or the need to turn a crank handle to start the engine, was not deemed 'seemly'. The process apparently was that, while waiting for his master, the chauffeur would carefully turn the crank handle a few times with the ignition turned off to prime each cylinder, then make sure No. 1 piston was not far past tdc. When 'sir' arrived, the ignition was switched on, and the advance/retard lever on the steering column rapidly moved to full retard and back which would introduce a spark on the spark plugs in the primed cylinders. The engine would spring into life and away they would go.
                      I saw this demonstrated a number times on the RR 20hp tourer mentioned above. It seemed to work about 4 times out of 5, which is still pretty impressive.
                      #302669
                      Jonathan Garside
                        @jonathangarside40968
                        Looks like AX 201 a 1907 40/50 Silver Ghost built in Manchester, now owned by Bentley Motors in Crewe. Reputably the most valuable car in the world.
                        Jonathan
                        #302683
                        John Flack
                          @johnflack59079
                          As no more as no more than a silly question, if you owned it would you actually use it??????
                          A story you won't believe , about 1960 drove my moggie to a club rally held in Malvern, I stopped at a garage on the bank of the R Avon it resembled an old coaching inn with a courtyard type stable/Garage units. The attendant looked at my vehicle and said "you into old cars.? I had a bloke done a runner owing garage rental of £150 , my solicitor says I can sell it to get my money back he unlocked a door revealing a type 35 Bugatti it's yours if you want it.
                          Being the weekend, 150 miles from home, in days before I had bank account or credit card I could do nothing but weep. I did say you would not believe it but it really is true.
                          #302691
                          Oldiron
                            @oldiron
                            John Stevenson :- If you look closely the bonnet is folded over to the near side. It has been lifted to show the engine off.
                            Gary
                            #302692
                            Geoff Theasby
                              @geofftheasby
                              Despite this being a 'deprived constituency', I've seen Mercedes convertibles, hot rods, Overfinch and Revere Range Rovers in this street in recent weeks.
                              Geoff
                              #302693
                              Phil P
                                @philp
                                Posted by John Flack on 15/06/2017 15:20:00:
                                A pal of mine obtained a couple of XK120 Jaguars in similar circumstances about five years ago. All he had to do was remove them from the garage where they had been left, within three days.
                                Phil
                                Edited By Phil P on 15/06/2017 17:14:49
                                #302711
                                  When my dad was much younger than I am, he saw some local wide boys trying to bump-start a Vincent HRD Rapide. He asked if they had changed the valves and they had. he guessed that hadn't ground down the valves to match the push rod wear (I think that was the problem) and offered them a scrap price for it. they said yes as they were on the verge of throwing it in the docks.
                                  He did it up, but ended up selling it when I arrived surprise
                                  A few years ago I tracked it down in an old issue of the Vincent Owners club newsletter — it had ended up in the hands of their chairman.
                                  John Stevenson 1
                                    @johnstevenson1
                                    Way back around 74, 75 we had a garage near us that dealt in old rolls Royces.
                                    Most of these were shopped to the States
                                    One day a friend called round and whilst we the talking he mentioned that old man Nudd had got an old rolls pickup round the back
                                    Now the pickup bit interested me so took a ride down and sure enough it was a pickup
                                    Car would be about an early 30’s big radiator, no silver lady obviously.
                                    Asked Nuddy about the history but he didn’t know
                                    I’m surmising that it was owned as a car by some estate somewhere and it it grew older it was replaced but they had the coach builders modify this into a pick up for the ground staff as the conversion was too neat for a hone built
                                    It wasn’t in bad nick for its year seats were all split and worn and the bed had seen better days but main problem was the engine had been robbed. No head manifolds, waterpump, dynamo or starter but that didn’t worry me as I fancied doing a lump transplant with a Commer TS3 engine of which we had loads kicking about.
                                    So asked how much and he wanted. 100 pounds
                                    Offered him 80 but he wouldn’t accept. Kept going back but neither of us would move on price
                                    No idea what happened to it,probably broke up for spares
                                    #302721
                                    Samsaranda
                                      @samsaranda
                                      In 1960 I lived on a farm in Devon for six months, as a thirteen year old I was in heaven, what a great life, used to help the farmer with milking there were a dozen cows which we milked by hand. During my stay there the farmer acquired a new car which was a 1920's Rolls Royce saloon, it was not in concours condition but because the boot lid opened and formed a level platform he found it ideal for carrying his milk churns on the opened lid. Every day he drove up the lane with the churns to leave them for the dairy Lorry to collect. He was regarded by his peers as somewhat eccentric before he acquired his Roller but more so afterwards.
                                      Robbo
                                        @robbo
                                        This must belong to a farmer. They keep telling me they can't afford new cars.
