Warco/ Myford mill problem
Home Forums Manual machine tools Warco/ Myford mill problem
  • #128356
    Michael Leech
      @michaelleech30848
      Thank you David as you can see I can now post.
      I have a Warco KF VO A1S turret mill which I think is an identical design to a Myford VM-E.
      I have a squealing sound coming from the spindle pulley set. The nut holding the pulley set is circular with four indents cut in the edge at 90 degree intervals. I have tried tightening/ loosening this nut with no success. Part of the difficulty is created by the fact that the machine has no spindle lock.
      Has anyone dealt with this problem before as I could do with some help with this.
      I have spoken to both Warco and (new) Myford but they claim that the machine is so old they no longer have any staff that can give advice.
      Michael Leech
        @michaelleech30848
        #128359
          Squealing is usually more a sign of a slipping belt than a loose pully. Could be a dry bearing, what does the spindle turn like by hand with no belts in place.
          If you have no spindle lock put a bit of 1/2" bar in a collet and hold that in the machine vice, failing that hold the collet/Autolock spanner in the vice while its engaged in the tool holder
          Edited By JasonB on 01/09/2013 16:27:50
          #128403
          Michael Leech
            @michaelleech30848
            With the belt removed and turning the pulley by hand I still get the squeal so as you suggest it may be a dry bearing, although I do lubricate at regular intervals. However I will try yor sugestion re locking the spindle.
            Many thanks
