Cutting back the trees which were overshadowing the panel provided a temporary solution, but it’s back. Despite the really sunny weather over the weekend we ran out of electrons. Nicked the battery out of an electric loco to allow us to continue. I’ve brought the (lead acid) batteries home and put them on charge via my Aldi ‘intelligent’ charger. Checking 20 hours later now says it is fully charged (4 bars) but only 12.8v. I think it should be up at 14v or so if fully charged. It is very old, probably 10 years+. Time for a new battery? Can I test it. It’s a deep cycle 24 AH, so an automotive tester doesn’t feel right. Just putting second battery on charge now, that is 36AH, but I suspect not deep cycle as it quotes 320A
We’re going to move the panel to away from the trees, and while we’re on add a second one. Do I simply put the new one in parallel with the old one?
Similarly, when the diesel genny is running it would be sensible to have that contributing. Any ideas on connection. Current thoughts are a relay which detects genny running and connects genny charger to battery, disconnecting the solar panels. Am I over thinking it? Running the genny full time is not attractive, if it hasn’t got a good load it soots up its injectors.
