Vertical boiler design
Home Forums Beginners questions Vertical boiler design
  • #134619
    nigel jones 5
      @nigeljones5
      Ive built quite a few in copper for small engines, but now want to build a steel one big enough to easily power a Stuart 5a sized engine without running out of steam! It will also need to provide enough power to allow the 5a to pump water to the boiler. Ive read a few books but cant fathom what size it should be. Any suggestions? Boiler will have 1/2" copper tubes, pre heat coil etc. Coal fed, conventional design. I recon it will need to be quite large! (You cant compare a horizontal loco boiler, they are just too different).
      nigel jones 5
        @nigeljones5
        #134623
        Tony Martyr
          @tonymartyr14488
          fizzy
          Not an answer to your query I fear but a fellow seeker!
          I have exactly the same problem although I would want to fit a ceramic gas burner rather than struggle with coal firing again.
          Since moving to deepest southern Shropshire I haven't found any of the model engineering fraternity within a days march of home so I will have to use this forum for advice.
          Tony
          #136389
          MICHAEL WILLIAMS
            @michaelwilliams41215
            Copy of pm sent direct to Fizzy a little while ago :
            Hi Fizzy ,
            Size depends on numerous things some of which are :
            Engine to run for demonstrations only or to develop significant power for some practical purpose ?
            Boiler to be worked hard with hot fire and forced draught or worked easy with soft burning fire and natural draught ?
            Boiler to work on basis of producing adequate steam continuously with only small reserve or generate steam at a slower rate with large stored reserve ?
            Whether boiler is to be used for 5a only or for general purposes where a larger steaming capacity might one day be useful ?
            I don’t know what you have in mind but for a general middle of the road design I would suggest something like 7 inches outer barrel diameter and about 14 inches high for the actual boiler – smokebox would be additional length . If size and weight don’t matter I would make it a bit bigger and work the boiler easy . If size and weight a problem I’d go for 6 inches / 12 inches and force the fire .
            Nothing is really critical as to proportions except that you need fire tubes relatively long compared to diameter .
            nb: A 5a can develop over 1/2 HP at 60 psi 1000 rpm .
            Regards ,
            MikeW
            #136423
            Paul Frost 1
              @paulfrost1
              Hi,
              How big a boiler? Try going to **LINK**
              Maccsteam.com has the formulas needed for you to work this out. 6” and 7” Copper tube is available, my big steam boiler is made from 1/2” steel pipe cant be moved without a crane weight is a big problem,
              Good luck
              Paul
              #137001
              MICHAEL WILLIAMS
                I was a bit preoccupied when this topic came up and couldn’t spare much time to think about it then .
                A few things have occurred to me since :
                (1) A vertical boiler of simple design can be made as a mechanical assembly – ie for the most part held together with screws and only some small areas needing welding .
                (2) A horizontal Lancashire type boiler similar .
                (3) If thinking about a steam raising device in abstract rather than a model of a conventional design boiler then many alternative designs and alternative construction methods become possible .
                (4) For conventional designs in larger model sizes there is nothing wrong with rivetted construction .
                Regards ,
                Michael Williams .
                Edited By MICHAEL WILLIAMS on 04/12/2013 11:26:42
                #137023
                Francois Meunier
                  @francoismeunier96697
                  Hi
                  for a large engine too, I was tempted to build a boiler similar to this one, riveted and soft soldered only, it looks nice and strong, or should I stop to chicken out and go for a brased job ?
                  Cheers
                  Zephyrin
                  #137030
                  hush
                    @hush
                    There is an excellent book titled Model Boilers & Boilermaking by K N Harris, it is a worthwhile book to search out.
                    full of ideas and technical information, it was published by Argus Books Ltd of Watford. in the 1980's
                    Regards Hush
                    #137057
                    Trevor Drabble 1
                      @trevordrabble1
                      I have some excellent copies of Model Boilers and Boilermaking by Harris , at least one of which I believe is hardbacked , which I was going to put on fleabay. Will try and establish a fair price over the next couple of days and will post for your consideration.
                      Trevor
