valve gear simulators
Home › Forums › Locomotives › valve gear simulators
  • #1883
    John Rutzen
      @johnrutzen76569
      #437878
      John Rutzen
        @johnrutzen76569
        Does anyone know of a stephenson's link simulator to run on a macbook please? Thanks.
        #437894
        Paul Lousick
          @paullousick59116
          I don't know of a Stephenson's simulator for a computer but modelled my engine in 3D CAD and can manipulate the model to check any scenario. I can raise/lower the Stephenson's link, rotate the crankshaft to any angle and check slide valve position.
          Paul.
          #437906
          John Rutzen
            @johnrutzen76569
            Thank you but I'm not into CAD. I wondered if any of the simulators could be run on a mac.
            #437911
            Paul Lousick
              @paullousick59116
              I'm not a Mac user but can't a Mack simulate a PC and run PC programs, even at a reduced efficiency ?
              #437923
              norm norton
                @normnorton75434
                On a Mac you load a program called Crossover, and that will run all manner of DOS written code within a specific window. Crossover costs a few pounds (i.e. not much) and although there are free alternatives they require a bit more thought to run. You can get all this information by searching the web. Ask for things like 'run windows programs on Mac' but you do not need a full windows emulator.
                Then there are a few valve simulators to download. Although most are Walschaerts I know that the Dockstader has Stephensons. Search for 'walschaerts stephensons valve simulators'.
                Edited By norm norton on 19/11/2019 09:47:20
                #437933
                Paul Lousick
                  @paullousick59116
                  This is a link to DON ASHTON'S STEAM LOCOMOTIVE VALVE GEARS.
                  which has links to simulators including one on Excel format. You will need a program that reads MS Excel files.
                  John Rutzen
                    @johnrutzen76569
                    Thanks for the help folks. I'll look into getting a programme to run windows but i've remembered an old windows laptop I've got somewhere so I may just try to crank it up.
                  Home › Forums › Locomotives › Topics
