vacuum brakes
vacuum brakes
  • #479945
    David Bothwell 1
      @davidbothwell1
      Another question regarding vacuum braking. Does the choke pipe have to run inside the boiler? I did not build the boiler for my locomotive and it does not have the fitting on the backhead or smokebox end? Hoped to run on outside and into smokebox Any help gratefully received!
      David Bothwell 1
        @davidbothwell1
        location of ejector pipe
        #479982
        Simon Collier
          @simoncollier74340
          Just exhaust the ejector to atmosphere. Both my engines have the ejectors pointing at the ground with no pipes on the outlet. You'll pull more vacuum and avoid a lot of unnecessary work.
          #480012
          David Bothwell 1
            @davidbothwell1
            Many thanks Simon, very useful
