Hi KWIL
Yes! You read my mind, am making a vertical screw vise. As you mentioned about extra weight is needed, I have given some thoughts over it. I saw a number of fly press photos constructed with extra loads at the flywheel for extra torque to drive the ram.
I’m not punching any sheet metal but more in using it for driving dowel pins rather using hammer as it’s noisy at night with neighbours nearby.
Will be using M10 at most, a normal thread to make or replace easily. Acme threads are better but needs to lathe cut, too much work here.
Advantage of it being adjustable in height, it will be useful for bearing insertion as I have a bearing puller already.
Steve
