Worked for me but not very helpful to anyone on several of the items
1. Bearing nut does not increase holding force, it reduces tightening force required to get the collet to hold correctly that is why there are two tightening torques given on most published tables – one for plain nuts the other for bearing nuts. If both tightened with the same force then the bearing one will grip more.
2. He is measuring the wrong part of the collet so they will be oversize
3. On smaller dia collets tool does not need to be inserted to full length of collet, just to full depth of the part that grips the tool
4. OK
5 OK
Edited By JasonB on 14/06/2020 13:34:16
