Upgrading Drummond spindle
Home › Forums › Workshop Tools and Tooling › Upgrading Drummond spindle
  • #389438
    Mike Waldron
      @mikewaldron61652
      Good morning all:
      I am a member of both the Drummond and Myford Yahoo groups, so anyone else who is will probably be already acquainted with this topic.
      I am currently considering upgrading my Drummond M spindle from the lean 1MT provision to ML7 thread + 2MT socket.
      Has anyone else done this? I would be interested to hear of your exploits.
      Also – in and around November 1960 to January 1961, a certain Mr Jennings rote a 5 part article about his upgrade of a Drummond Admiralty model, using his other one!
      I guess he is no longer with us, but did anyone know him?
      #19195
      Mike Waldron
        @mikewaldron61652
        #389443
          It wasn't a Drummond, but that's probably of no importance
          Way back … I did something similar:
          I made a screw-on boss for the existing nose and fixed that in place; then [in situ] turned a vee groove at the joint line. … Then dismantled the lathe and took the spindle to be mig-welded … reassembled the lathe and finished the machining of the new nose.
          Stepping things forward just a little did help make room for the 2MT socket without weakening the spindly spindle.
          Mike Waldron
            @mikewaldron61652
            Michael:
            My thought is not to go the whole hog and enlarge the spindle, bearings and bored as Mr Jennings did, but merely to make a larger nose register and thread.
            A slight enlargement of the front journal can be accommodated – just – apparently, so that’s my course of action once the weather gets a bit warmer.
            #389449
            Ady1
              @ady1
              It's a huge job and an interesting project but considering the amount of work involved I would just go out and buy a Boxford
              The spindle is the "easy bit"
              Absolutely everything has to be upscaled to back it up, a new pulley would need to be cast etc
              A 1 inch bore would need what? a 2 inch spindle?
              Myford have a big bore so that could give you the basic dimensions
              Probably easier to adapt and bolt an atlas 10 inch headstock to a drummond bed
              But even the mighty atlas 10 inch only has a 25/32" bore
              #389450
                Posted by Mike Waldron on 05/01/2019 09:07:25:
                Michael:
                My thought is … merely to make a larger nose register and thread.
                Which is what I did ['though the exact details are a fading memory]
                I just shifted the register face a little [towards the tailstock] to avoid weakening the spindle by enlarging its MT size.
                May I suggest that you first draw a sectional view of the current arrangement, and overlay 2MT, to identify any potential weakening.
                Ady1
                  @ady1
                  You could probably squeeze a 2MT into the existing spindle
                  Then use an adaptor for fitting Myford bits
                  #389481
                  Bazyle
                    @bazyle
                    There is a pdf drawing on the Yahoo Drummond files section for an M spindle. Scaling that on my screen to be lifesize I held a M2 taper over it and there is room for 3 inches of depth so may need to look at the thin end.
                    For anyone wanting to try drawing their own the critical dimensions are: Nose 1in threaded x 0.5 in long, register 1.125 x 0.375 long, then flange 1.49 x 0.28 long, then journal 1in x 1.833 long. After that it gets a bit tight at 0.873 dia which needs to have the pulley keyway so you could modify this bit to give half an inch of extra length.
