Unusual vertical slide
Home Forums Manual machine tools Unusual vertical slide
  • #271147
    Mike Payne 1
      @mikepayne1
      Hi,
      I have just acquired this vertical slide that I think is unusual in that it has a v-groove cut in the table and a conical (concave) base.
      I'm sure these are original features as it looks unused, just slightly tarnished from storage. The table measures 3 3/4" x 8".
      Does anyone have any idea of the lathe it is meant to fit?
      I will be using it on my Raglan probably with a t-slotted table.
      Thanks
      Edited By Mike Payne 1 on 11/12/2016 11:33:09
      Mike Payne 1
        @mikepayne1
        #271151
          Mike,
          Sorry, I don't recognise it … but it looks an excellent design yes
          For the convenience of others: **LINK**
          http://s988.photobucket.com/user/mikebeetle/media/IMG_0396.jpg.html
          Mike Payne 1
            @mikepayne1
            Sorry I have just edited links.
            #271158
              Nice an meaty! The relieved base will sit flat easily. You could use a V-block style u-clamp to hold round stock in the V.
              #271164
                The table looks remarkably like this [for Boxford] **LINK**
                https://goo.gl/images/2ZEg1h
                Mike Poole
                  @mikepoole82104
                  I think it might be by Harrison.
                  #271180
                    Posted by Michael Poole on 11/12/2016 13:19:34:
                    Pretty sure you are correct, Mike
                    There is a photo of it [fully kitted-up] here: **LINK**
                    http://www.lathes.co.uk/harrison/page3.html
                      Posted by Michael Gilligan on 11/12/2016 13:34:43:
                      Well found, I think that's what they mean by 'fully loaded'
                      "its mounting boss was hollowed out to provide clearance for the (optional) 4-way toolpost indexing pawl"
                        Posted by Neil Wyatt on 11/12/2016 14:29:18:
                        Can you recommend a "fit for purse" modern equivalent, Neil ?
                        … or should I continue looking for a vintage one?
                        devil MichaelG.
                        #271206
                        Mike Poole
                          @mikepoole82104
                          I think this has come up before here **LINK**
                          #271215
                          Mike Payne 1
                            @mikepayne1
                            Thanks all for the replies. Have never seen one set up for gear cutting like that!
                            #271230
                            not done it yet
                              @notdoneityet
                              Mike,
                              Post it up on the Raglan forum. There might be some help from there.
                              #271285
                              Howard Lewis
                                @howardlewis46836
                                My pal has a Raglan, Little John, so if would have to fit in place of the toolpost, (No T slot on the Cross Slide).
                                Also, from memory, it would need an adaptor to match the Cross Slide.
                                Anything helpful on the Lathes website, whi ch is usually a mine of good info?
                                #271288
                                  Posted by Howard Lewis on 11/12/2016 21:48:52:
                                  Yes … the link that I posted at 13:34:43 today angel
                                  Edited By Michael Gilligan on 11/12/2016 22:08:17
                                  #271378
                                  Mike Payne 1
                                    @mikepayne1
                                    Happy that it is a Harrison slide. Thanks all. Might be able to justify that T-slotted cross slide I have been looking at for ages now!
