It might be worth persisting in checking the thread core diameter, and pitch. This should give a better idea, but bear in mind that if it is Imperial, the thread form will be 55 degrees rather than the 60 degrees.of Metric or Unified..
Since it is old stock, you may well find that it is Imperial. 24mm is 0.9449 inch. This is just over 15/16", although this is not Myford 7 Series, or the earlier ML2s and 4s..
