Twinner Multi-Jigset (what is this tool for?)
Home Forums Workshop Tools and Tooling Twinner Multi-Jigset (what is this tool for?)
  • #559723
    AJAX
      @ajax
      I bought a pair or matching clamps from a local car boot sale. 50p each. Three of the jaws are missing (easily replaced) and I don't have an immediate use for them, but they have an excellent clamping action and appear well made.
      Before I consider re-purposing or modifying them, does anyone recognise them or their original use? They are marked Twinner Multi-Jigset and 2195.
      20210824-123308 20210824-123344 20210824-130051
      The only "information" I can find via the Internet is a number of sellers on eBay trying to sell them without any apparent knowledge of what they are for.
      AJAX
        @ajax
        #559736
        David George 1
          @davidgeorge1
          Hi I have used similar clamps as part of a holding jig to hold larger pieces for drilling and milling.
          David
          #559738
          not done it yet
            @notdoneityet
            IF it sells, or you could get another one, on sbay. Good bargain for a couple of clamps for a quid
              John Smith 47 should be impressed … it’s nearly what he was wanting.
              Mike Hurley
                @mikehurley60381
                to me these look like adjustable tools to set things over a certain amount. I would think that a range of different jaws would have been available to suit the job in hand, the screw thread is fine adjustment for amount of ' throw ' and the lever actually closes the jaw and provides the set.
                I'm thinking here typically of the tooth set on either hand saws or circular saw blades. I have a similar ( but more compact type ) for just this purpose – called a saw set and made by Eclipse. The types in the photos would possibly just be more versatile versions of this?
                regards Mike
                #559787
                AJAX
                  @ajax
                  Posted by not done it yet on 25/08/2021 07:29:16:
                  I don't think anyone would be foolish enough to pay so much for these clamps. Of course, if anyone happens to know such a fool then feel free to put them in touch!
                  #559788
                  AJAX
                    @ajax
                    Posted by Mike Hurley on 25/08/2021 09:03:10:
                    regards Mike
                    Thanks Mike. I assumed it was some type of mechanics tool but you may well be right.
                    #559791
                    AJAX
                      @ajax
                      #559804
                      Clive Foster
                        @clivefoster55965
                        Seeing the full kit complete with base suggests that its fundamentally a more robust version of those "helping hands" devices having croc-clips on pivoting mounts / arms primarily intended for holdin electronics stuff in mid air for soldering.
                        I'd think that this, more robust, device was either more in the brazing together line of work or for holding up one or two things in line so another part can be screwed on.
                        #559805
                        Robert Dodds
                          @robertdodds43397
                          From the E bay photos they look like early forerunners of today's toggle clamps.
                          Graces Guide throws up some pictures of big positioners and welding fixtures for the welding trade made by Donald Ross and Partners under the name Twinner. from the phone number I guess the company dates from the 50's 60's era
                          Bob D
                          #559838
                            Thanks to Robert’s discovery … I have just found this:
                            Improved Welding Technique. — A new
                            development to be included in the 1952
                            British Industries Fair, to be held in
                            London and Birmingham from May 5
                            to May 16, is an improved method of
                            welding known as the "Twinner Tech-
                            nique''. The basic idea is that universal
                            holding tools are set up on the top plate
                            of a welding positioner to receive the
                            workpieces to be welded. The holding
                            tool acts as a jig, and being mounted
                            on the welding positioner, the work-
                            piece can be positioned to suit the weld-
                            ing procedure. Complicated weldments
                            can thus be built up rapidly from a
                            series of sub-assemblies with special jigs,
                            the sub-assemlies being brought together
                            as a final assembly on the welding posi-
                            tioner.
                            This method is claimed both to econ-
                            omize considerably in production time
                            and to eliminate the cost of special jigs.
                            The ''Twinner Technique" is made by
                            Donald Ross and Partners. Limited. 1-3
                            Arlington Road, London, N.W.I.
                            Ref. **LINK**
                            https://archive.org/stream/transactionsofen35engi/transactionsofen35engi_djvu.txt
                            and also another address [in 1964] , at Twinner Works, Gatwick Road, Crawley
                            Keep digging !
