Toolpost Miller
Toolpost Miller
Home Forums Workshop Tools and Tooling Toolpost Miller
  • This topic has 5 replies, 4 voices, and was last updated 4 May 2017 at 22:50 by NICHOLAS ELLIS.
  • #296402
    NICHOLAS ELLIS
      @nicholasellis10828
      I have purchased a chinese spindle motor, with variable speed, which can be mounted as a toolpost miller, gear cutter etc.'The unit looks fine but comes with a #n ER11-A collet which is for a rather too small 1/8" shaft.
      This collet holder is mounted on the motor shaft, which is 1/4" and looks as if it is held on by 2 grub screws.
      However If I slacken off or remove these screws It will not budge, even with a puller. If it is threaded, which I doubt, there is no way to hold the shaft to undo it.
      I was hoping to buy a similar holder for an ER 20 collet, so I can use it with Thornton cutters, for cutting wheels for clocks.
      Does anyone know how to remove this collet holder please? Your comments woild be most gratefully received!
      N,Ellis
      NICHOLAS ELLIS
        @nicholasellis10828
        setting up with a spindle motor
        #296412
        Nick Wheeler
          @nickwheeler
          I set mine up as it came:
          and
          That's the vertical slide left over from my mini-lathe mounted to a Wm250, and the spindle motor mount bolted directly to it.
          To answer your question, I think the collet holder is machined directly into the spindle.
          Edited By Nicholas Wheeler 1 on 04/05/2017 18:25:54
          #296420
          Nick Hulme
            @nickhulme30114
            Posted by NICHOLAS ELLIS on 04/05/2017 17:29:23:
            ER11 Collets are available up to 7mm
            #296433
            Martin King 2
              @martinking2
              Hi guys, can you pls post a link for this spindle supplier?
              Martin
              #296452
              NICHOLAS ELLIS
                @nicholasellis10828
                CNC ROUTER MILLING Air-Cooled 0.4KW Spindle Motor & PWM Speed Controller & Mount
                Look for this on ebay. Nick
