Tiny split pins.
Tiny split pins.
Home Forums Beginners questions Tiny split pins.
  • #9980
    David K
      @davidk77137
      David K
        @davidk77137
        I have been making some M3 castle nuts which will require split pins when fitted.
        What is the preferred method to make tiny split pins
        #441531
        Chris Gunn
          @chrisgunn36534
          David, I have some 1/32" pins if they are any help, PM me
          Chris Gunn
          #441533
            Well you could by 1/32" ones (0.8mm) which is about right for a 3mm or 1/8" shaft from the usual ME suppliers
            If you want to make your own then in the past I have filed 0.5mm steel wire down to half thickness and then bent to shape. A shallow Vee milled into some flat bar holds the while while you file it.
            Finished job through 1/16" diameter pins
            #441614
            David K
              @davidk77137
              Thanks , I did not realise you could buy them that small . That said I think mine will need to be
              a little smaller than 1/32 so I will get some wire.
              Thanks for the offer Chris
              #441625
              Graham Swales
                @grahamswales
                One trick that I have used is to cut a length of wire and hold it under tension in a piercing saw frame. You can then draw file the wire to the required section before cutting and forming.
                Grum
                #441626
                old Al
                  @oldal
                  you can by smaller still if you look for them on ebay. type in split pin and all will be revealed. Done it myself a year ago. cheap as well
                  #441630
                  Chris Gunn
                    @chrisgunn36534
                    David, that's OK, I have several boxes I will never use, hence the offer.
                    Chris Gunn
