Those funny drill saw things…
Home Forums Manual machine tools Those funny drill saw things…
  • #371354
      I'm guess that, like me, you've probably bought sets of bits that include a weird one that resembles a drill on the end but is studded with coarse rectangular teeth.
      My understanding was always that they are for drilling a hole then working sideways like a crude saw.
      I finally used one today and it worked very well.
      The material was the 305mm very heavy density plastic pipe that is the tube for my dobsonian telescope. I had to enlarge the focuser hole to about 100mm, bigger than my largest holesaw and anyway no centre to guide one.
      It was actually fairly easy to cut a neat hole and just tidy it up with a rasp. The focuser has a cover plate so a perfect hole was not needed although it came out much tidier than I expected.
      Even on plastic it cut rather than melted (it was a TiN coated one) and I found gently working it up and down sped things up, presumably by keeping the teeth clear.
      Nice to know they work, wonder if I will ever use one again?
        AJW
          @ajw
          I have a set of them.
          Just need the telescope to use them!
          Alan
          #371371
          Mike Poole
            @mikepoole82104
            I have a few kicking around, will have to give them a go.
            mike
            #371374
              I should say I used it in a hand drill – I coldn't fit a 1' by 5'8" tube on my mill…
              #371377
              Dalboy
                @dalboy
                If they are what I think then I use them a lot when doing piercing work on my woodturning great tools and remove material very fast
                #371391
                Brian G
                  @briang
                  Posted by Neil Wyatt on 11/09/2018 21:33:09:
                  How fast were you winding the handle to worry about it melting the plastic?
                  #371425
                  David Standing 1
                    @davidstanding1
                    That's because you have a Fisher Price toy mill laugh
                    #371439
                    Ian S C
                      @iansc
                      I think Neil used a hand held power drill, hand power doesn't work too well sideways.
                      Ian S C
