If I remember correctly the problem with diesel engines in cars is that the cylinders are too small to complete combustion. A large engine, as fitted to a ship, has huge cylinders and runs at low rpm. It's relatively easy to get good air/fuel mixing and plenty of time for the oil, and partial combustion products, to burn more completely,
I think it was Ricardo who first produced the first practical diesel engine small enough to fit a lorry. He added a swirl chamber that forced the combustion deeper into the cylinder, and got more oxygen to the oil.
A car engine has small cylinders and it develops power by turning at high rpm. It seems that the various clever improvements since Ricardo have not succeeded in making a small engine that doesn't leave Nitrogen Oxides and Carbon Particulates in the exhaust.
The latest moves to restrict diesel cars are because the current Government has been successfully prosecuted twice. First for failing to meet emission targets, and then a year later for failing to do anything about the first judgement. Very embarrassing.
Nitrogen Oxides are the most dangerous pollutant, and are estimated to cause 20,000 to 40,000 deaths per year in the UK. There is also concern that particulates are not decreasing as fast as they they should be. Possibly this is down to engines being configured to pass tests rather than reduce emissions in the real world.
Those Nitrogen Oxides don't kill people in an obvious way. If just standing next to a diesel car bumped you off, then there would be no controversy. What actually happens is that Nitrogen Oxides in the air makes other lung / heart conditions much, much worse. It kills sick people who would otherwise have survived. As we don't know the victims personally, it's very easy to dismiss the statistics and forget that these are real people with grieving relatives.
As others have said, the big problem with electric vehicles is the battery. Everything else about electric out-performs Internal Combustion. They are faster, cheaper to make, simpler, cleaner, and more efficient. Apart from the power source! My fortune would be made if only I could invent a cheap, safe, high-capacity secondary battery good for 300 miles that can fully recharged in 5 minutes.
Typos!
Edited By SillyOldDuffer on 04/05/2017 11:36:43
