Tachometers sensor magnet
Home › Forums › Electronics in the Workshop › Tachometers sensor magnet
  • #495972
    Ian Parkin
      @ianparkin39383
      I need to fit a tachometer on a machine in the morning
      how do i fit the small button magnet to a shaft?
      if i glue it to a mild steel shaft does the steel sap the magnetism ?
      #32137
      Ian Parkin
        @ianparkin39383
        #495979
          Araldite worked OK on mine
          #496036
          Steviegtr
            @steviegtr
            Posted by Ian Parkin on 15/09/2020 18:22:14:
            No it will be fine.
            Steve.
            #496042
            Brian Sweeting 2
              @briansweeting2
              Make sure that you stick the magnet the right way around, you just know that it will happen.
              #496141
                I found the small neodymium magnets are so strong that popping one in a keyway or spanner notch has always worked for me without adhesive.
                Enough!
                  @enough
                  … which probably makes Brian's admonition even more important cheeky
                  #496231
                  Ron Laden
                    @ronladen17547
                    I have fitted one to my mill and one to the lathe ( dry with no adhesive) and neither have budged yet.
                    Edited By Ron Laden on 17/09/2020 07:07:17
                    #496263
                      My lathe's magnet sits in a slight recess, which I guess gives it more grip on a machined flat surface and stops it sliding on a smooth round shaft.
                      Sliding may be a problem – although I can't imagine a strong magnet coming off, it might move sideways. Sideways movement may not show up in practice. Provided the magnet's close enough right-left to activate the hall sensor, rpm will still be measured. Even if a magnet gradually walks around the circumference, the effect on rpm readings will be small.
                      A spot of glue would also stop sideways movement and be less trouble to apply at home Another guess; it's cheaper for the manufacturer to machine a flat recess on a lathe spindle than it is to clean it carefully and apply a glue resistant to oil and heat. Also easier to fix an unglued magnet if untrained labour puts it on upside down.
                      Ian Parkin
                        @ianparkin39383
                        I did the job today just ground a flat on a 20mm silver steel shaft and placed the magnet and it stays there even at 1000rpm
                        its been running an hour or so now
                        I had it in my head that a magnet would have need putting in a non ferrous collar to work adequately
                        thanks for all the help with this
