My lathe doesn't have a through bore on tailstock to allow 'knocking out' – When I use tools without a tang on the end of the Morse taper, I have to find an alternative way to remove from the tailstock. The thick jaws of a small Whitworth spanner I have can be placed around the exposed part of the Morse taper, then I wind the tailstock back in – the taper gets jacked out of the socket. The spanner jaws (or a custom made 'fork' ) has to be smaller across flats than the largest diameter of the taper to remove (say) a hard centre, if there is a larger 'head' attached to the taper, jaw size is less critical.
Edited By David Jupp on 19/01/2017 08:41:11
Edited By David Jupp on 19/01/2017 08:41:42
