Stuart Turner engine and boiler
Home Forums General Questions Stuart Turner engine and boiler
  • #144786
    Dougie Swan
      @dougieswan43463
      Hi
      My son has been given a ST engine complete with boiler and dynamo to restore
      Inside the boiler casing is some insulation, could this be asbestos?
      Dougie
      Dougie Swan
        @dougieswan43463
        #144796
        Jeff Dayman
          @jeffdayman43397
          Yes it could.
          Don't disturb the material while it is dry. Airborne asbestos fibres are very hazardous. Don't keep the unit indoors.
          If you soak the whole asbestos-containing works in a pail of water and keep it outdoors,wet, it will reduce risks considerably.
          Look in yellow pages or google for your local asbestos abatement professionals – they will tell you how best to deal with it safely and for a small item like this, probably quite cheaply. They may just ask you to remove screws then bring it to their shop or an abatement site wet and in a sealed plastic bag, where their technicians will deal with it and give it back to you washed and cleaned of asbestos.
          Glass wool or kaowool is a good replacement.
          Good luck, be safe. JD
