Steam Drain cocks
Steam Drain cocks
Home › Forums › Locomotives › Steam Drain cocks
  • #385372
    Alan maddern
      @alanmaddern76909
      Hi any advice on how to stop steam activated drain cocks on my 5 inch loco from clogging up and not working and how to clear them again Thank you Am
      #1781
      Alan maddern
        @alanmaddern76909
        #385379
        Jeff Dayman
          @jeffdayman43397
          Are they clogging with rust or scale or ? Knowing what the clog is may help ID some actions to keep it from happening again.
          Probably best to dismantle them and poke them out with wood sticks, pipe cleaners etc. as required (and keep all debris found for examination)
          #385392
          Paul Lousick
            @paullousick59116
            Copper or steel boiler ? Rust or scale ? Stored wet or dry ?
            To prevent contaminants use clean water and correct water treatment.
            Blow down at every steaming to flush out boiler.
            #387396
            peter wilkins
              @peterwilkins27856
              FIT AUTO DRAINS FROM KENNIONS…..£10 OR LESS EACH
            Home › Forums › Locomotives › Topics
