Steam Boiler
Steam Boiler
Home Forums General Questions Steam Boiler
  • #26540
    MICHAEL Moore 1
      @michaelmoore1
      Construction material
      MICHAEL Moore 1
        @michaelmoore1
        Hi
        Can anyone tell me if inconel 740 steel can be used to build a boiler for a 5ich gauge loco
        #404179
        Thor 🇳🇴
          @thor
          Most states in Australia accepts model boilers made from "Duplex" stainless steel. Have you contacted your club boiler inspector about using Inconel steel, you may have trouble getting it certified.
          Thor
          #404232
          Paul Kemp
            @paulkemp46892
            Not in England you can't if you want to go the club testing route as the code specifically precludes stainless as a generic and I imagine NI is the same, not sure about the South though. You might be OK with a commercial test and a commercial insurer as long as you can do the numbers and get a design approved. Could be complicated and expensive though!
            I can see the logic precluding stainless as a material given its propensity for cracking and sudden failure but other places in the world as well as Europe allow it, maybe we are stuck in the dark ages.
            Paul.
            #404235
            DrDave
              @drdave
              With a maximum Fe content of 3%, Inconel 740 is hardly a steel! It is designed for the superheater section of a coal-fired boiler in a power station, but does its cost not make it less attractive, even given the probable difficulties in trying to get a boiler certificate.
              #404241
              Boiler Bri
                @boilerbri
                Has anyone read the code that the Australians use for stainless steel boilers?
                Bri
                #404274
                Thor 🇳🇴
                  @thor
                  Posted by Boiler Bri on 08/04/2019 20:27:44:
                  Bri
                  I only found these on the Internet, seems you have to buy a copy, others may be able to find it.
                  ***Link***
                  ***Link***
                  Thor
                  #404281
                  Martin Johnson 1
                    @martinjohnson1
                    " You might be OK with a commercial test and a commercial insurer as long as you can do the numbers and get a design approved. Could be complicated and expensive though! "
                    I have just completed that route for a conventional steel vertical firetube boiler. 18 pages of calculations, many pages of risk assessments, installation and operation instructions etc. etc. later, plus over £1500 lighter in the wallet department just for design approval and independant testing. I cover some of this in an article coming up in the next issue of EIM.
                    In short, that sort of money will buy you a hell of a lot of copper and silver solder.
                    Martin
                    #404292
                    Simon Collier
                      @simoncollier74340
                      There has been a concerted effort by some senior people to have the Australian codes put on the net for all, but the AMBSC reckons they can't afford to forego the money from selling them. There was an article in AME on the testing of a Duplex boiler, for a 7-1/4 Darjeeling B, a few years back.
                      #404305
                      Samsaranda
                        @samsaranda
                        I would imagine that machining the inconel would be challenging, we used to machine it at one company I worked for and I know that inconel castings were a real pain. We were using machining centres that could use the correct speeds and feeds and had plenty of power.
                        Dave W
