Small bore gauges
Small bore gauges
Home Forums Workshop Tools and Tooling Small bore gauges
  • #382180
    sean logie
      @seanlogie69385
      I'm looking to get myself a small bore gauge set .What would you recommend ,the ball type or the flange type .
      Sean
      sean logie
        @seanlogie69385
        #382200
        Kettrinboy
          @kettrinboy
          Sean ive got a 4 piece ball type set and find the two bigger ones that go from about 5mm to 13mm are pretty easy to get the right feel and the measured size with a mic is within about 0.01mm when compared with using a precision plug gauge ,so I use these a lot ,but the two smaller ones that do 3 to 6 mm are a bit more tricky to get the feel of because they spring a bit and getting a definitive mic reading is more difficult so I would still rely on plug gauges to err gauge the exact size of a sub 5mm hole, but as they are relatively cheap I think they are well worth getting.
          regards Geoff
          Edited By Kettrinboy on 25/11/2018 09:16:43
          #382217
          Rik Shaw
            @rikshaw
            Sean – These are what I use. The Moore £ Wright gauges in the brown envelope are what I use most. Given the choice though I would use a go – no go plug gauge every time for final sizing (if I had some!).
            NOTE for mods. Trying to upload pics to my album now crashes Chrome every time in ver. 70.0.3538.102 and also 70.0.3538.110 both 64-bit. I had to resort to Edge to upload this one. Hope this helps.
            Rik
            Edited By Rik Shaw on 25/11/2018 11:04:13
            Edited By Rik Shaw on 25/11/2018 11:05:38
            #382232
            Hopper
              @hopper
              Ball gauges under half inch. T gauges over half inch. Get the good quality ball gauges because they have better "feel" due to being better made with a more full ball shape. Some of the cheapies have a sort of half-ball which works OK but not as nice for fine measuring.
              #382254
              Fowlers Fury
                @fowlersfury
                Endorse Hopper's comments…..
                Some years ago Model Engineer offered a free set of those depicted in the blue plastic wallet above with an annual subscription. They were really rough, no precise feel to them ~ donated to the m.e society's next auction.
                Definately recommend making go-no-go gauges to use when bore and gauge at same temperature !
