Size of threads on milling arbor
Home Forums General Questions Size of threads on milling arbor
  • #364625
    Jens Eirik Skogstad 1
      @jenseirikskogstad1
      Hi folks, i has bought milling arbor with 3/8 treads for drawbar. I has tried with 3/8 tap, do not fit in the 3/8 treads. Which size is treads on 3/8 drawbar? I must create a new drawbar for milling arbor with 3/8 size.
        @jenseirikskogstad1
        #364626
          Try 3/8" whitworth
          #364627
            @jenseirikskogstad1
            Also it’s 16 treads on 3/8?
            #364628
              Yes 16tpi on 3/8" Whit
              #364629
                This nicely summarises UNC / Whitworth compatibilty: **LINK**
                https://rycote.zendesk.com/hc/en-us/articles/204439391-3-8-Thread-Standards
                  @jenseirikskogstad1
                  Thanks a lot! Now i can create a new drawbar with 3/8-16 and i has already 2 drawbar with 12mm and 1/2″.
                  #364634
                  Martin Connelly
                    @martinconnelly55370
                    m10 x 1.5 is very close to3/8" x 16tpi. I would check if it is M10 as well as 3/8" x 16.
                    Martin C
                    #364637
                      Posted by Martin Connelly on 30/07/2018 08:23:40:
                      Martin C
                      +1 for that possibility.
                      They're so close you can convert one into the other by gently running a tap into the female thread. I wouldn't recommend it for everything, but it's an OK bodge on a drawbar.
                      Edited By SillyOldDuffer on 30/07/2018 09:11:39
                      #364638
                        @jenseirikskogstad1
                        I has tried with M10, will not distort the treads.. best to use correct size.
