A little bit more info:
It's a grain crusher which does indeed require, I think he said, 200 kW. But since the OP, he's also said that the rpm required is about 500 so he's now thinking, in broad terms, that if it was geared down from 1500 (nominal), then that would possibly reduce the motor & genny requirements by about a third.
FWIW, between them they do have a lot of heavy duty equipment. I've seen some of it – huge tractors with 16 or more gears. In each direction at that! A device which is literally dragged through the ground to overcome the cumulative effects of the ground being crushed; hedge cutters, post knockers, etc.so I'm not that surprised at the power requirements.
Anyway, he's having another think.
I think what I'll do is point him at this thread, then he can digest the info herein at his leisure.
Many thanks,
Peter G. Shaw
