Silver Steel
Silver Steel
Home Forums Beginners questions Silver Steel
  • #7317
    Jack Foreman 1
      @jackforeman1
      Jack Foreman 1
        @jackforeman1
        How do I visually tell the difference between silver steel and any other bright round bar? Or do I need to determine by passing a file across it?
        Thanks
        Jack
        #164899
        Thor 🇳🇴
          @thor
          Hi Jack,
          besides the obvious – look for the word STUBS at the end, what about a spark test, here's another. The spark test may not be able to distinguish between high carbon steels though.
          Thor
          Edited By Thor on 28/09/2014 15:57:23
          #164917
          Mike Poole
            @mikepoole82104
            It will have a ground finish and be accurately sized, usually 13" long as purchased but longer lengths available. If it hardens after heating to cherry red and quenching and has the accurate ground finish it's a good chance it is silver steel.
            #164944
            John Burridge
              @johnburridge26484
              does anyone know if you can still get square silver steel?
              #164949
              Rik Shaw
                @rikshaw
                All the replies to Jacks OP are pukkha. As for square silver steel? – Well I've always treated sawn sections of gauge plate the same as I do for round silver steel – if it gets hot – it gets hard!!
                Rik
                PS I agree that if the round stuff is marked "STUBBS" then you have got the best there is.
                Edited By Rik Shaw on 28/09/2014 21:36:05
                #164958
                JohnF
                  @johnf59703
                  John B , Yes you can get square silver steel most engineering supply houses should have it. I got some from Thomas Graham locally ( Lancaster) a few months ago .
                  #165007
                  ronan walsh
                    @ronanwalsh98054
                    Silver steel is lovely steel to work with and easy to heat treat, one problem i do find with it is its not very resistant to corrosion and rust. I often found that if i handled it one day, the following day there would be rusty fingerprints on it. The main use i have for it is making small metal cutting chisels.
                    #165528
                    John Burridge
                      @johnburridge26484
                      I have found that College engineering services keep some square Silver Steel
                      I wonder if anyone know if KEA108 with seleainum is still available,this is a free cutting silver steel which the clock makers seem to use for pinions because of it good free cutting machinability.
                      #165557
                      Ian S C
                        @iansc
                        ronan, the higher the carbon content of steel, the greater it's susceptibility to rust, compare silver steel to wrought iron, once that has a thin film of oxide it will last for years without further rust.
                        Ian S C
                        #165564
                        KWIL
                          @kwil
                          It is also a known fact that some people have naturally more agressive fingerprints due to the nature of their body fluids.
                          I fortunately have an almost neutral skin and long ago I was the only one allowed to handle some of the metrology gear as it was "safe" with me.smiley
