Sharpening drills
Sharpening drills
Home › Forums › Beginners questions › Sharpening drills
  • #69800
    Colin Jacobs 1
      @colinjacobs1
      Just wanted to say how a friendly lot you all are, just been to Great Yarmouth to see an ME who sharpened all my drills. and showed me how to make a jig.
      Thanks mate
      #5537
      Colin Jacobs 1
        @colinjacobs1
        Thankyou mate
        #69816
        WALLACE
          @wallace
          Couldn’t have been a CNC drill sharpener then . . .
          W.
          #69820
          Colin Jacobs 1
            @colinjacobs1
            sorry don,t get the joke
            #69886
            Speedy Builder5
              @speedybuilder5
              Been readin Model Engineer dated 1950 something.
              The writer claimed he could sharpen a drill to make a hole as accurate as a reamer and had been doing this for a number of years. His secret was to sharpen as normal, then grind off the very tips of the outer edges of the cutting edges . It looked as though the cutting angle was a normal 118 deg and then the outer corner of the lip (.020 – .040) ground to about 45 deg.
              #69889
              Dusty
                @dusty
                I have used this method or a slight variation of it for years. my method is to stone a small rad on the lip of the drill. To be accurate these rad’s should be of the same size otherwise the drill will only cut on one side and tend to cut oversize. The other thing is you need to leave only a few thou to take out with this drill, much the same as a reamer. The finish that you get in the hole, provided you feed slowly is generally better than a reamer. The other problem is that if the original hole is not round or off line then the drill will follow it. It is a trick worth knowing, have a little practice on something that does not matter until you are confident in your ability before you use it in anger.
                #69893
                David Clark 13
                  @davidclark13
                  Hi There
                  This method works well.
                  You probably won’t get the drill in the hole if you try it by hand afterwards.
                  regards David
                  #69901
                  WALLACE
                    @wallace
                    Hello Colin – the joke being that the the recent thread about CNC in MEW wasn’t what I would call ‘friendly’ !!
                    W.
                    Edited By WALLACE on 07/06/2011 19:06:40
