Both the Tom Toms that we have had, countdown to road junctions / roundabouts, from about half a mile out
After quarter mile, it counts down in yards, in 5 yard decrements..
It won't tell you how far you've come, but how much further you have to reach your destination. But it will tell you road / street names as you approach them.
Sometimes the updates get a bit confused. On the A14 it it will tell you stay on the A14 for 50+ miles as you approach the M6 junction, but once you are on will admit to being on M6.
So don't believe all that it tells you
(Sometimes "Turn Right" actually means take the corner! )
With ANY Sat Nav, be wary of post codes for a destination.
In town, you may only need to choose between two houses. In the country, you may have the choice of twenty square miles!
The map display (Larger selected by a touch on the screen ) shows which way the road bends. It tells you which exit to take from a roundabout, BUT needs to be kept updated.
The "third exit" might be new one since the last update, leading you into a housing estate rather than onto the slip road for the A!!
Edited By Howard Lewis on 18/06/2021 18:02:28
