Resiliant or standard metric foot mounted motor?
Home Forums Manual machine tools Resiliant or standard metric foot mounted motor?
Viewing 15 posts - 1 through 15 (of 15 total)
  • #383528
    derek hall 1
      @derekhall1
      Hi guys,
      Just a quick couple of questions, I am currently looking at converting my Myford S7, which has the original resiliant "imperial" single phase motor, to the popular 3 phase invertor route via Newton Tesla or Transwave for example.
      The main issue is deciding on the type of motor. I can get in one package a resiliant "imperial" motor that dimensionally is the same as the old one, or I can choose a slightly different motor this being a "metric" foot mounted (non resiliant?) motor which is slightly cheaper. Chosing the metric motor option will mean some"iron fighting" as the existing pulley will need machining to suit the new metric motor shaft and also some packing (effectively large shims) will need to be made as the centre line of the motor is different to the imperial motor.
      So imperial straight swap or metric option?….by the way the metric motor has a fan whereas my current old single phase motor has no fan….is this an issue following the conversion as the motor may not always be running at its "normal" speed so the fan may become less effective?
      What are your experiences on this?
      Regards to all
      Derek
      derek hall 1
        @derekhall1
        Myford invertor conversion
        #383531
        Martin Kyte
          @martinkyte99762
          Is there a reason (maybe price?) not to get the complete motor/ inverter package from Newton Tesla?
          Comes fully wired as a bolt on package. £469.20
          regards Martin
          #383532
          Mike Poole
            @mikepoole82104
            I fitted a foot mounted motor as I felt the resilient mounting would be unnecessary withe the superior smoothness of a three phase motor. I am happy with my decision.
            #383534
            AJW
              @ajw
              I fitted to my ML7 a Crompton Greaves 3 phase motor and I did have to put some holes in the motor plate.
              Best mod I have ever made! Rarely have to alter belt on pulley even with parting off, so smooth. Not resiliently mounted but runs almost silently. It is a sealed motor with external fan in a cowel and I did fit a deflector to help prevent it drawing in dirt and swarf.
              I powered it from a Bosch Rexroth VFD with remote control pad – the whole lot came to under ?200
              Alan
              Edited By AJW on 03/12/2018 13:34:53
              Don’t know what happened to the pound sign!
              Edited By AJW on 03/12/2018 13:35:40
              #383541
              Clive Foster
                @clivefoster55965
                Resilient or solid mount is more a factor with single phase motors which are inherently a bit more vibratory than single phase ones. Resilient may still be a bit smoother but can't see it mattering here.
                Unless the price differential is significant straight swap imperial is the best option. In my experience "just" jobs as in "just machine out the pulley bore" and "just fit some shims" come with whole platoons of gremlins in tow with big sharp teeth waiting to bite you on the bum.
                Fan speed is pretty much a non issue with modern name brand vector drive inverters. They are very good at supplying just enough power to the motor so heating is much less than the old style, simple frequency variation, drives which tend to have significant internal circulating currents warming things up but doing no real work. Power output at very slow speeds is inevitably low so you probably won't do it much. Old fashioned though the ± 1/3 rd name plate speed range for normal operation is it still remains very much the sweet spot where things just work as you expect them to.
                #383542
                John Haine
                  @johnhaine32865
                  The 3-phase motor I just fitted to my Unimat is mounted hard down to the baseplate, not a trace of vibration. Resilient mount not necessary IMO.
                  #383562
                  Philip Rowe
                    @philiprowe13116
                    A couple of years back I converted my S7 to a 3phase conversion courtesy of Transwave. Being lazy I stayed with an imperial motor to save the problem of shaft diameter and I have not regretted it, in fact the only problem was the annoyance with myself for not having done the conversion years ago. A long afternoon's job or a short day and it was complete and that included making mounting plates for the remote and the inverter. When I first switched it on to test it, I initially thought that it wasn't working as the control pot was set at about half way and there was no noise or vibration whatsoever. It was only when I spotted the pulley rotating that I realised that indeed it did work.
                    Phil
                    #383583
                    HughE
                      @hughe
                      Hi Derek
                      Converted my S7 last year using the Transwave package with metric motor, non resilient mount. As Phil said, wish I had done it years ago. It's very quiet, which means I can use the Lathe late a night without waking the wife up. I only had to make three changes.
                      1) New pulley to fit metric shaft. I do not know if you can modify the existing pulley. I did not, as I did not have facilities to bore it out to size. RDG sell one with the correct bore size.
                      2) I had to modify the Myford mounting plate by slotting the holes by a few mm. I used M8 coach bolts.
                      3) Turned the motor connection box around by 180deg so the cables exited facing down. Also fitted the cable to the temp sensor if required in future, the lathe is in a awkward position to do this in situ. You may not need to do this it depends on the Lathes location.
                      Other than that it was plain sailing. It's a good idea to set it up on a bench first to check it all works (make sure the motor is fixed down first). I would suggest before you start you make a support structure to hold the motor mounting assembly when fitting.
                      If you pm me I can sent some photos .
                      Hugh
                      Edited By HughE on 03/12/2018 18:37:48
                      #383586
                      Bodger Brian
                        @bodgerbrian
                        Posted by Clive Foster on 03/12/2018 13:48:42:
                        Something needs editing, methinks.
                        #383590
                        HughE
                          @hughe
                          Just add batteries !!!!!
                          #383592
                          Clive Foster
                            @clivefoster55965
                            Posted by Bodger Brian on 03/12/2018 18:42:10:
                            Ooops! Edit induced error. Should read "nherently a bit more vibratory than three phase ones".
                            #383630
                            Norfolk Boy
                              @norfolkboy
                              My Harrison M250 was a factory 240Volt motor with twin link belt and a weighted flywheel and resilient feet, which shows how much they thought a 240V motor needs damping. I fitted a 3 phase motor no resilience as per Harrison 3 phase spec and matched v belts and the difference was not just noticeable but remarkable. The machine is smooth and quiet. I would have no hesitation in hard mounting the motor if you are going 3 phase VFD. That said if it is the easier option I see no harm in fitting a resilient type of motor.
                              Alan
                              Edited By Norfolk Boy on 03/12/2018 20:22:43
                              Edited By Norfolk Boy on 03/12/2018 20:23:12
                              #383645
                              roy entwistle
                                @royentwistle24699
                                AJW re absent £ sign, Check you've not got an American keyboard. Happens to me everytime windows 10 updates.
                                Roy
                                ps To change it back if it is. Prsss Windows key + Space
                                #383762
                                derek hall 1
                                  @derekhall1
                                  Thanks all of you for your responses.
                                  What a great forum this is. Someone somewhere has the answer!
                                  General consus seems to suggest that the conversion is a "no brainer" anyway…
                                  Regards to all
                                  Derek
