I am building a rear mounted tool post for an inverted parting off blade. On the designs I have looked at the blade is:
1. horizontal and the cutting edge fixed at centre height
or
2. at an angle so that ‘top’ rake is introduced and the centre height of the tool can be adjusted.
If I adopt 1, there is no top rake and if I ground one on the blade this would upset the centre height each time it was sharpened. An advantage though is that the tool overhang can be reduced to suit the job in hand.
With the blade at an angle, as in set up 2, this provides top rake and adjustment of centre height but has the disadvantage of maybe having too much over hang for a given diameter and conversely may also limit the diameter that can be parted.
My question is do I need top rake on a parting tool blade and which is the preferred option?
Regards John
