Last year I bought a laser cutter, A3 sized. before buying it I did a fair bit of research as to what i would use it for. Worked out that it would be 10% workhorse and 90% John's toy and hopefully get better.
Currently it's standing at about 60% work and 40% toy but in all fairness of that 40% my grand daughters , 9 and 10 use it more than i do.
Point being is that once you get the technology it soon expands to niche markets you never thought of.
That hole in the middle is 0.75mm and the other one on the arm is 0.5mm.
Those gaskets which take 14 seconds to cut get a new lease of life out of a £125 vacuum valve.
All that goes wrong with the valve is crud on the brass seat, a quick clean and it's fine but they don't sell a gasket, only a new valve. The gaskets rip when stripped and cannot be reused and sealant only gets in the vac lines.
It's been costing the company about £250 a month on replacements.
Edited By John Stevenson on 26/06/2013 23:26:55
