I have a QuickStep mill, I actually made it to the Original designer’s design notes [not as a kit] which were published in MEW.
To answer you questions in order. As used on Myford S7
Are they any good? For me it has a small number of useful attributes. I can just pick it up, lock it on the toolpost with the standard QC fitting and cross drill, slot/spline. Other uses are up to you, have you seen the blurb sheet from Hemmingway?
How do you change gear? Thre is a 3 step pulley on the rear under the black cover, there is also a 3 step gear box withing the body, operated by the knob on the side, all changes are with the motor stopped. Motor is DC, so I can also very the speed by powering from AC variable source [Variac].
Are they well made? Mine is!! I have seen none kit versions on Hemmingway’s stand at shows and they appear to be OK. Fwd/Rev switching is interlocked, you have to pass through Stop
I have a higher than standard speed motor which gives me 4000rpm If interested I can find the internal photos.
K
Edited By KWIL on 17/11/2010 09:48:37
