Primer problem
Primer problem
Home Forums Beginners questions Primer problem
  • #7203
    GaryM
      @garym
      #155690
      GaryM
        @garym
        I'm usually too cautious. "Measure three times and cut the following week" could be my motto. However, the other day after doing some final fettling of the S50 base casting that I'm building, I degreased it and gave it a coat of red oxide primer. That bit was OK, the mistake came when I got the flywheel I'd prepared the previous week and painted that, forgetting I hadn't degreased it. Therefore the finish is glossy and very slightly soft compared to the matt and sound finish on the base.
        Should I give it another coat of primer or try and remove it with paint stripper or rub it back to metal?
        Thanks
        Gary
        #155691
        stevetee
          @stevetee
          A mate of mine who is a better engineer than I will ever be made the observation "90% of paint problems are to do with adhesion." I suspect he is probably right, if the item hasn't been de-greased then you will struggle to get the paint to adhere to the base material, due indeed to the thin layer of oil. Try wire brushing the paint, if it comes off in sheets you will need to redo it sooner or later, so why not now. If the brush glides over the finish, as it probably would on the matt item ….. you are OK.
          #155693
          stan pearson 1
            @stanpearson1
            Hi Gary
            Go to your car paint supplier and buy 5lts of gun wash its like celli thinners and will cost about £10 that will wash it off without marking it and if you can afford it buy some self etching primer spray a thin coat and leave for 24hrs to etch. Don't mess with red oxide.
            stan
            #155694
            GaryM
              @garym
              Thanks for the replies guys.
              Looks like you are both suggesting getting the primer off. I think I knew that was probably the correct course of action. So I'll have a go at that with cellulose thinners and/or abrasives. I didn't want to spray it because I've zero experience of spray painting and masking the flywheel would have taken a while and probably not been that successful. Also, just to clarify, the castings have been machined, the engine tried on air and this is the final stage before final assembly.
              Gary
              #155696
              Oompa Lumpa
                @oompalumpa34302
                Stan is absolutely on the money with his advice. Red oxide primer is for road bridges.
                (though £10 a gallon for gunwash….. I buy it in 25 litre – 5gal – containers for about that. I use LOTS)
                graham.
                #155705
                Tim Rowe 1
                  @timrowe1
                  SteveItee's mate is correct and the old adage that a good paint finish is at least 95% in the preparation. Red Oxide – "Off with its head"!
                  #155761
                  duncan webster 1
                    @duncanwebster1
                    If it's oil based red oxide then caustic soda will shift it, cheaper than thinners and easier to dispose of. Wear rubber gloves, it's wicked on your skin
                    #155775
                    stan pearson 1
                      @stanpearson1
                      Hi Graham
                      Yes your right it was antibloom thinners I bought as I spray all my locos in celli.
                      Stan
                      #155806
                      GaryM
                        @garym
                        Thanks for the suggestions everyone, I'll take them on board, but what is so bad about red oxide primer? I try to find as much info as I can before asking questions. I have Chris Vine's excellent book "How (not) to paint a locomotive" and realise that acid etch primer is very useful, but due to it being a small casting and brush applied I thought red oxide would be OK in this instance. Top coat will be Humbrol enamel.
                        Gary
                        #155832
                        Russell Eberhardt
                          @russelleberhardt48058
                          There's nothing wrong with red oxide primer for clean iron or steel I've used it on everything from models to vintage car chassis with no problems. Of course there is good and bad quality. The old "red lead" primer was a better rust preventer but the Elfin Safety boys have stopped that.
                          For brass, bronze, and aluminium you do need to use an etch primer or it won't stick.
                          Russell.
