PP Thornton (successors)
Home Forums Clocks and Scientific Instruments PP Thornton (successors)
  • #497343
      I don’t use Facebook, but I stumbled across these whilst searching for something this morning: **LINK**
      https://www.facebook.com/PPThorntonsuccessors/videos/10201053960773462/
        Some interesting short videos …
        #497351
        John Haine
          @johnhaine32865
          Good link, thanks Michael! Now if we had a video of how they shape the profiles on their HSS blanks…
          #497365
            Posted by John Haine on 23/09/2020 10:29:27:
            The frustrating thing, John, is : I’m sure I have seen one [or at least some photos] years ago.
            They cut the HSS with a carbide profile tool, in the lathe, I believe.
            ega
              @ega
              I hastened to view MichaelG's linked video lest it be censored (I admit I don't feel sure about the working of the new rules).
              I suppose that the oil in the sump beneath the cutter is there to capture any grinding dust that doesn't go into the funnel?
              #497405
                John,
                Thanks to the wonderful digital archive … and to my own search skills angel
                I have, at last, found what is probably the definitive article about cutter manufacture at
                Horological Journal
                December 1995
                pp 416-418
                by J K Nicholson
                John Haine
                  @johnhaine32865
                  Aha! Good stuff, I'll peruse that.
                  #497432
                  John Haine
                    @johnhaine32865
                    Well, that was an interesting read Michael! Not entirely clear, but it seems that they produce the cutters using in effect the "button" method to impart the required profile to the teeth, the "buttons" (or their equivalent) being made from carbide, ground to shape using diamond wheels. The "soft" 12-tooth HSS blank is turned on a form-relieving lathe after gashing, then vacuum heat treated to harden. Doesn't sound easy to reproduce at home!
                    #497436
                    Baz
                      @baz89810
                      John Haine if you substitute gauge plate for soft HSS and use the Ureaka form relieving attatcment it is perfectly do-able in the average workshop.
                      #497438
                        Posted by John Haine on 23/09/2020 17:53:09:
                        Not forgetting the pantograph reduction, and the inspection work
                        …. suddenly, it makes the price look very reasonable
                        John Haine
                          @johnhaine32865
                          Posted by Baz on 23/09/2020 18:02:00:
                          Indeed, but in another thread people have been discussing manufacture of HSS tools on the Quorn.
                          #497454
                          Martin Kyte
                            @martinkyte99762
                            Posted by Michael Gilligan on 23/09/2020 18:32:18:
                            Especially as they do a sharpening service at half the price of the cutter.
                            regards Martin
