Like Brian, I too have an Axminster 4×6 which often shed its blade on deep cuts.I use a new bi-metallic blade. I read the document mentioned by Eric and concluded that the problem was faulty tracking. Unfortunately, as Brian also mentioned, the blade guide castings were so badly made that it was impossible to align the flat of the blade vertically, so I resorted to machining them. The improvement was dramatic. I was able cut a slice from a 10×100 steel bar ( flat edge vertical) without shedding the blade, and the cut was just about a perfect 90 degrees. Problem solved, I thought.
The 10×100 cut was the deepest I'd attempted, but came the day when I had to cut a lump of 75×100. It started well and I was full of confidence, until the blade came off at a cutting depth of about 80mm. I reset the blade and continued. It came off again. After resetting the blade again I noticed that it didn't re-enter the cut properly. The top of the cut was perfect, but on lowering it carefully it was clearly 'binding' on one side, more and more as the blade was lowered. I loosened the bar in the vice and repositioned it so the blade wasn't binding at the bottom of the cut, and was then able to complete the cut, but why did the blade cut a 10×100 bar vertically but not a 75×100 bar?
I'd used a set-square to verify that the blade side was vertical – it still was. But because of restricted access near to the hinge, I hadn't bothered. That was the mistake. The blade wasn't vertical nearest the hinge – it was, in fact, slightly twisted front to back. It didn't seem to matter for the 10mm thick bar, but 75mm was another matter. After removing the twist it continued to cut the thick bar properly. YMMV.
