Have a look at a BA set, which firemen use
Ships have them
I recharged bottles all the time in the 1980s up to 2-300 psi(or was it BAR) with zero issues and all metal connections
Diving people will refill air bottles all the time as well
There hasn't been a problem with this issue for decades
siebe gorman made a lot of gear, it screwed straight on and off for recharging using nothing more than hand tight connections, zero issues, ever
If you are going to play about then use high pressure water, not air
Dunlop or someone managed to kill about 5 employees the first time they tested a large tyre to destruction with air pressure. It literally exploded, like a bomb.
They always used water after that incident
The bit that always amazed me was the demand valve, which let you breathe normally even though you were carrying the equivalent of a bomb on your back.
Edited By Ady1 on 05/07/2012 01:17:33
