Plastic Balls in Bearings?
Home Forums General Questions Plastic Balls in Bearings?
Viewing 25 posts - 26 through 50 (of 56 total)
  • #397843
    Jeff Dayman
      @jeffdayman43397
      +1 for steel ball brgs vs plastic when replacing failed ones.
      Vacuum cleaners are a throwaway product these days and are always built down to a price like all mass market appliances. If they last the warranty period length plus a couple weeks that is mission accomplished.
      Dyson's real achievement is a marketing and advert campaign that convinces people that their vacuums have better or more "leading edge" technology than other brand appliances. Take one apart and you will see very little actual technical innovation, but lots of visual gimmicks with transparent cones, funnels, bits going around, and lots of inaccessible areas jammed with dust and lint.
      Their stuff may be designed in UK but look at the boxes and it is made in Thailand and Malaysia.
      I'd say the best empty catchphrase they have gotten away with is advertising they have a 'digital motor'. Digital motor control circuit, sure, but 'digital motor', that's just marketing / advertising hot air.
      My opinion only – Just my $0.02 worth – your mileage may vary.
      Edited By Jeff Dayman on 25/02/2019 04:27:21
      Edited By Jeff Dayman on 25/02/2019 04:27:58
      John McNamara
        @johnmcnamara74883
        Hi All
        Hi all If you have not experienced Ave then you may be in for a shock. And yes he does have a very fruity command of the English language… Er Canadian with all that prevails in the tundra.
        He has a passion for taking Dyson gadgets to bits!
        So put your hard hat on and dig in for a bumpy ride.
        I must admit I think he is rather skukem.
        Chris Trice
          @christrice43267
          Dyson BTW are the top bar on the graph outselling their nearest rival by three to one.
          Edited By Chris Trice on 25/02/2019 09:23:08
          #397863
          blowlamp
            @blowlamp
            Posted by Chris Trice on 25/02/2019 09:14:04:
            I wonder why? Everyone I know that owns one has had problems with them from very early on.
            Martin.
            #397883
            Jeff Dayman
              @jeffdayman43397
              The company have a very skilled marketing and advert staff – that's all. They can convince people to buy them.
              Mr AvE calls it as he sees it – and he knows cheap consumer grade crap when he sees it apart.
              #397892
              Chris Trice
                @christrice43267
                Don't we all?
                #397899
                Jeff Dayman
                  @jeffdayman43397
                  One further AvE video observation – in AvE's review of the Dyson "Ball Animal" vacuum he finds an off the shelf Panasonic vac motor inside.
                  No issue at all with them using this motor – Panasonic vacuums have done very well at our house – had two, both went about 5x the warranty life, at about 1/3 the cost of a Dyson. The Panasonic vac motors are pretty good, I'd say, based on my experience. However, Dyson advertised this Ball model as having revolutionary new Dyson motor technology.
                  My wife foolishly listened to a colleague's recommendation and bought a new Dyson vac between the two Panasonic ones we have bought. The Dyson product was a major disappointment from the start, it just did not perform, and it needed several repairs in the first month (broken switch actuator levers, broken latches, split hose). We passed it on to another couple who desperately wanted a Dyson and were also disappointed. With the two Panasonic units, no such nonsense at all.
                  #397921
                    The odd thing about Dyson is they seem to invest in customer support and replacing faulty parts rather than reliability.
                    They have been wonderful at replacing failed parts for their machines, but in contrast my Earlex/Wickes Workshop vac is 17 years old with no fails* and Hetty is about 8 with no signs of wearing out.
                    *Aside from about 1/2" at the end of the nozzle being worn away by me rubbing it on a swarfy carpet and the time I spilt Ferric Chloride in it and had to open it up and replace the on off switch as a result.
                    #397961
                    Sam Stones
                      @samstones42903
                      Hi Will,
                      I sent you a PM.
                      Sam
                      #397964
                      Sam Stones
                        @samstones42903
                        Neil Wyatt wrote …
                        It's more than odd Neil – I would go so far as to say –
                        The odd thing about Dyson is they seem to invest in customer support and (yet) replace faulty parts with faulty parts.
                        After months of emailing; three replacements; submitting a lengthy technical report; one of eight brave bods let me into a secret.
                        I should look for the product release number. Any product prior to this (and I can substantiate this from the replacements we received) should be suspect.
                        Sam smile d
                        #397985
                        Geoff Theasby
                          @geofftheasby
                          Re: Dyson, I originally got one because they are good at picking up dog hair. They filter the air, which helps asthmatics, they do not lose suction, you can see when they are full. I also have a newer VAX. It clogs up regularly, sometimes every time it is used. It is lighter, and it is cordless.
                          #398008
                          Cornish Jack
                            @cornishjack
                            If you feel that you really have to pay that sort of silly money for a vacuum cleaner, go for real quality with a Sebo … no, I don't have shares but I DO have two such and with HEPA filters they will certainly sort out the hairy dog problem – we have cats … same sort of problem!
                            rgds
                            Bill
                            #398038
                            Howard Lewis
                              @howardlewis46836
                              Our Panasonic is so old that I cannot remember when it was bought.
                              The only problems have been the hose coming out of the end fitting from time to time (several years) and the brushes wore out on the large head, which combined with the rollers failing, made a replacement necessary.
                              My wife used to fund raise for a local cat refuge, in the market.. Next door was a stall selling spares for vacuum cleaners. he seemed to have huge array of parts for Dysons, not many for Panasonics.
                              As a suspicious Luddite, cannot but fear that the Dyson is leading edge high tech, but possibly like Clkive Sinclair's advanced engineering, less durable / reliable
                              If I wanted a vac for the shop, I would opt for a Numatic, (Henry or one of his cousins).
                              #398050
                              Bazyle
                                @bazyle
                                I recently got a small ash vac from Lidl. Intended for sucking up the ash from a fire grate so short hose and no carpet tool. It is ideal for the workshop as is takes less space than the wet'n'dry and sucks harder than any I've ever known. Obviously I call her Monica. I doubt it has a good duty cycle so wouldn't do for a wood shop but metalworkers mostly only need short stints.
                                #398053
                                Sam Stones
                                  @samstones42903
                                  After drafting my note directly into this forum, including my opinion that much of their design was impressive, when I hit the Add Posting ‘GO’ button my note blew away into cyber space.
                                  In revamping what I had written, I forgot to include that the shift to overseas manufacture seemed to spell the start of the technical problems.
                                  The good news has been that I repaired the fault on the three devices with nothing more than some reinforcing wire and a few blobs of Araldite.
                                  Anyone wanting to see/learn more of my saga should PM me with their return email address.
                                  Sam smile d
                                  #398062
                                  Sam Longley 1
                                    @samlongley1
                                    Most of the pullies on my yacht have delrin balls in the roller bearings in them. The furling gear , which takes considerable load applied by a winch, has delrin balls in the swivels
                                    #398069
                                    Chris Trice
                                      @christrice43267
                                      Presumably because of the corrosion steel bearings would suffer in close contact with sea water. Plastic bearings are more than capable in non dimension critical situations.
                                      #398070
                                      Chris Trice
                                        @christrice43267
                                        Back in my car restoration days, I used to specialise in Triumph sports cars and the lower front bronze trunnions of the Herald/Vitesse/Spitfire/GT6 cars, that carried all the weight of the front of the car, had simple plastic bushes shaped like top hats about 11/16" OD and 9/16" I.D. with a steel sleeve inside that. Yes, they wore eventually but they were easy to fix and obviously deemed up to the job.
                                        Edited By Chris Trice on 26/02/2019 20:07:33
                                        #398137
                                        Howard Lewis
                                          @howardlewis46836
                                          Following the comment from Chris, about suspension bushes.
                                          In the 70s, Leyland Leopard buses and coaches with Dunlop air suspension, used two Glacier DU top hat bushes for the each of the shackle pins on the taper leaf spring which acted as radius arms to locate the axles.
                                          The wear was not on the circular part of the bush, thanks to the automatic chassis lubrication, but on the side face (Brim of the Top Hat ) The side play on the front axle would eventually reach the point where there was wheel wobble ( presumably caused by the castor angle fighting the misaligned wheels ) One extreme case despite locking one's arms and shoulders, shook the powered doors open. A certain Vehicle Off Road until new bushes had been fitted.
                                          A quick and nasty short term fix was to shim the side play with a large washer, to keep the vehicle running until the new bushes arrived, and could be fitted,;usually next day
                                          Howard.
                                          Excess word deleted
                                          Edited By Howard Lewis on 27/02/2019 17:08:01
                                          #398139
                                          Jon Lawes
                                            @jonlawes51698
                                            Posted by Chris Trice on 26/02/2019 20:06:29:
                                            Funnily enough I'm about to look at a solution to the trunnion design on my GT6. The high kerbs at some circuits does give it all quite a beating and someday I suspect a trunnion will make a bid for freedom. I see some based on a Caterham design are knocking around but I really would like a better solution. I could be tempted to start from scratch with rose joints.
                                            #398156
                                            Chris Trice
                                              @christrice43267
                                              Rose joints are great for racing but they tend to wear quickly. All the exotic kit cars like GT40 replicas use them but they wear badly and make the car a bit of a bone shaker on the road. Actually the Triumph front wishbone suspension units were very highly thought of. Lotus used them on their early Elans. The secret is to keep the threads on the bottom of the trunnion well lubricated. Better not to talk bout the rear end unless you have the rubber doughnut rear suspension.
                                              #398173
                                              Ian P
                                                @ianp
                                                Posted by Chris Trice on 27/02/2019 18:55:16:
                                                'Better not to talk bout the rear end unless you have the rubber doughnut rear suspension.'
                                                Why?
                                                Ian P
                                                #398176
                                                Chris Trice
                                                  @christrice43267
                                                  Transverse leaf spring and a tendency for the rear wheels to tuck under. The system was tweaked to make it slightly better on later cars but still somewhat tail happy in the wet going around roundabouts. The rubber doughnut version used a lower wishbone rear rather than letting the axle shafts take the strain.
                                                  #398178
                                                  Chris Trice
                                                    @christrice43267
                                                    …… together with a sudden loss of grip at the rear end as the axles swing under the car pivoting at the UJ at the differential. There is no slow transition. It tends to go from grip to no grip very quickly.
                                                    #398252
                                                    Howard Lewis
                                                      @howardlewis46836
                                                      Closing the throttle, or braking, when cornering on any swing axle car i( such as the original VW Beetle, Triumph or Skoda 100 Series) will cause the rear wheel to tuck under. This usually precedes a visit to the the local countryside!
                                                      As Chris says, the transition from safe to Whoops! is pretty rapid, and not to be encouraged.
