piston ring
piston ring
Home Forums Beginners questions piston ring
  • #382716
    Philip Burley
      @philipburley44197
      when tempering home made piston rings should they be cooled quickly or slowly ? U tube videos show both methods ,
      regards
      Philip Burley
        @philipburley44197
        #382728
        not done it yet
          @notdoneityet
          The heating simply removes any ‘set’ the rings had when made. They will retain the new shape on cooling, so it makes no difference. Only when heated again, will they lose that ‘set’ and only then if their shape were changed physically. Hopefully they never would, in their usable lifetime.
          I would think that slower cooling would, if anything, be better than quenching – less chance of distortion.
          #382729
          Brian H
            @brianh50089
            Personally, I would cool them slowly.
            #382771
              I always cool mine as slowly as possible. Also make sure you heat them evenly otherwise they will move at the hottest point first and you will get egg shaped rings.
              Edited By JasonB on 28/11/2018 18:21:37
              #382941
              Philip Burley
                @philipburley44197
                thanks for the information , I heat treated them today with slow cooling and am very pleased with the result , , gapped them and they fit perfectly . remarkable !!!!!!!!!!
