My Son was a Blue water engineer, and served on a granite chip boat that worked between Ireland and Rochester and occasionally to Spain, one trip to Spain was trouble. As they approached santander the engine bent a con rod and they were stuck about 5 miles out of the Port. The captain ordered the anchor dropped but it ran out all the chain and still did not hit bottom.
To save salvage charges he called the pilot boat and they were pulled in slowly, but of course the anchor chain ! The winch could not lift the anchor wieght and chain so they had to cut it away.
Once in harbour my Son checked the engine and removed the offennding con rod by tying it up out of the way. The journel, he put a sealing bandage around it and used big Jubillee clips to hold and then obtained permission from Lloyds insurance to run the engine in that condition but at 5 knots only.
They came back to Rochester and parked up alongside the Harbour on the Chatham dockyard by a crane.
Called in the heavy brigade who proceeded to lift the crankcase off the engine bed to expose the crankshaft. By then they had cut a large aperture in the bulkhead to lift through the old crankshaft. A new one from Doxford arrived. But, the straight edge suggested that the engine base was distorted, This is where I came in with an optical device (Auto Collimator) that I could measure the deviation of the bed. I did this and found that in fact the bed was 278 thou. down at each end and about 170 in the middle. This meant they needed a new engine bed.
It duly arrived and was via the crane lifted down and through the hole in the bulkhead and set down in place of the damaged one. Then the new crank was fitted and crankcase bedded down and all was well. To my knowlede the bed and old crankshaft are still there on the dockside.
The boat was leased to a chap but the Insurance paid up and he lost his lease and the owners wanted him to work as a Night security till it was paid off what they paid the heavy gang, needless to say my Son upped and went to Norway to work on the boats from an Under water gas and oil survey company. He is now their Logistics and trouble shooter in Houston in Texas.
