Optical Centre Punch any good?
Home Forums General Questions Optical Centre Punch any good?
Viewing 25 posts - 1 through 25 (of 39 total)
  • #385448
    Mark Gould 1
      @markgould1
      Gents,
      I have to ask for a Christmas gift and thought of asking for an Optcal Centre Punch. Are these any good? Pros and cons? Any things to look for, brand etc?
      Thanks,
      Mark
      Mark Gould 1
        @markgould1
        #385452
        geoff adams
          @geoffadams14047
          been looking for one now my eyes are going used to have one in the tool room at work where have you seen them
          Geoff
          #385458
          Swarf, Mostly!
            @swarfmostly
            Hi there, Mark and Geoff,
            I have the Soba version of the optical centre punch. I felt it was a bit of an indulgence when I bought it but I have found that it enables me to achieve a precision that I couldn't manage with the naked eye.
            You'll look at it and wonder how on earth there'll be enough light at the bottom of the optic to illuminate your scribed lines but, somehow, there always is. You do need to look DOWN it though, I don't know how one could use it on vertical or inverted surfaces.
            Best regards,
            Swarf, Mostly!
            #385460
            Brian Wood
              @brianwood45127
              Mark and Geoff,
              I manage pretty well with a cheap magnifying glass and lean the point of the punch over so that you can see when it is actually on the crossing point of the layout lines; hold it down at that stage and carefully bring it upright before punching the mark
              A fine tip to an auto punch will do well, to be followed by a heavier one if the mark needs to be deepened.
              As for grinding a new point, try holding the punch in a power drill, making sure it runs reasonably true and put a new point on from the side of the wheel. I am right handed so I run the drill in reverse and use the right hand side of the wheel. A good light is helpful.
              #385463
              Maurice Cox 1
                @mauricecox1
                I have had one for years. I wouldn't be without it. I can't remember the make, but the body of it is shaped like an inverted bucket and has an "O" ring set in the underside to prevent slipping. I did try one that had a larger body with an inner piece that rotated to change from lens to punch. I found that one too cumbersome.
                Maurice
                #385466
                Mark Gould 1
                  @markgould1
                  Thanks for the speedy replies gents, i share the hobby with my Dad who is 76 so I think I’ll ask Santa to pick one up.
                  @Geoff, I am based in the Netherlands and have seen them on Hogetex.nl but I just googled and found that Axminster amd Warco sell them too. Also you could try eBay.
                  #385470
                  Vic
                    @vic
                    There was an article in MEW showing how to make your own for those so inclined. We had a bought one at work and it was very good.
                    #385472
                    Hillclimber
                      @hillclimber
                      Yes. Yes. Yes.
                      As a younger fellow my eyes may have been better. But this is the only way I can now be sure of hitting the mark.
                      I see that Warco are out of stock, but they were selling them at £28. This is the kind I have.
                      Cheers, Colin
                      #385473
                        Although I tend to do a lot less marking out now I have the DRO on the mill I still like my optical punch for things that matter, my Veritas one was a Christmas gift some time ago. Should be available from UK woodwork suppliers.
                        #385474
                        Peter Simpson 1
                          @petersimpson1
                          I have the Soba version. I need to use a jewelers loupe with it. Brilliant and very accurate.
                          #385488
                          Richard Marks
                            @richardmarks80868
                            Had the Axminster Tools version for over 10 years and it does the job.
                            #385534
                            John Reese
                              @johnreese12848
                              I've had one for probaby 40 years. It works beautifully. The base on mine is faced with cork. It hold its position nicely when switching from optic to punch. I wouldn't recommend one without the cork face. I have not used mine much lately as I do most of my layout using the DRO on the mill.
                              #385541
                              Reg Wortley
                                @regwortley
                                +1 for Veritas, made by a Canadian company the lens magnifies the cross hairs 8 times making it very easy to put the centre in the correct place.
                                #385557
                                Marcus Bowman
                                  @marcusbowman28936
                                  I have the same kind as John. Works well. I made some punches with finer points to use in it, as I am used to using a 'pricker' punch. I generally try to avoid having to centre punch anything, but when I need it, the OCP is within arm's length on the corner of the shelf above the bench. I wouldn't be without it.
                                  Marcus
                                  #385562
                                  the artfull-codger
                                    @theartfull-codger
                                    I have a dankroy and wouldn't be without it, not sure if they still make them but they are really good, for rough work I use an automatic punch then a good whack with a hammer and punch. I also have a hobbies archamedian drill with home forged spade bits made from silver steel hardened and ground to 59 degrees and a few twists and the drill starts spot on (tubal cains idea) TD Walshaw not the American one.
                                    #385566
                                    Emgee
                                      @emgee
                                      Plus 1 for the Dankroy although I don't use mine all that often, as said DRO saves a lot of marking out.
                                      Unfortunately the maker of these retired a couple or so years ago so only second hand units available.
                                      Emgee
                                      Edited By Emgee on 14/12/2018 05:51:22
                                      #385569
                                      thaiguzzi
                                        @thaiguzzi
                                        Posted by Vic on 13/12/2018 14:46:30:
                                        Indeed. Made my own, not difficult, nice little weekend project, just have to find the raw materials, ie a short length of perspex rod.
                                        #385570
                                        I.M. OUTAHERE
                                          @i-m-outahere
                                          On mine i found the cross hairs were not on centre so if i turn the acrylic rod they wobble around the centre punch mark , not much though probable a few thou so i just average it out . The do type is spot on and one day i might make a new acrylic rod with accurately centred cross hairs . I also made a simple optical cenre device for the mill , i got the plans through a guy that made some videos for the mini lathe and mill called swarfrat but it was a while ago and not sure if he is still selling them . It works ok but in reality no mre accurate than the pointer on a wobbler .
                                          #385582
                                          IanT
                                            @iant
                                            I use my Dankroy for any accurate centre punching. The case is getting a little grubby from handling but it still works very well (you have to take care to look straight down over it) – especially as my eyesight is not as good as it was.
                                            As Emgee say's the maker is no longer in business – which is a pity, as it is a quality product. Another case of where at the time (20 years or so ago) I do recall it seemed an expensive purchase but now (many years later) I can't remember the actual cost….
                                            IanT
                                            #385592
                                            Hopper
                                              @hopper
                                              Being blind in one eye and unable to see out of the other, I do mine by braille. A fine pointed prick punch can be felt to drop into one scribed line, then pull it along the line until you feel the point hit the other line THEN just a click more as it crosses the burr on the edge of the scribed line and drops into the valley of the line proper. The fine punch makes a fine dot of course, so usually is followed up with a larger punch before drilling starts. Like most things, practice makes perfect. ( Well almost perfect, well most of the time…)
                                              It helps greatly to have a good quality, sharp scriber that cuts a clean line into the metal below the marking blue.
                                              Edited By Hopper on 14/12/2018 10:09:45
                                              #385594
                                              Anonymous
                                                I don't have an optical centre punch, so obviously I don't use one. But neither do I miss one. I hardly ever mark out. Edge finders, DROs and 4-facet drills have pretty much made marking out redundant for my machining. I suspect I get better accuracy using the above as opposed to marking out.
                                                The main exception to the above is sheet metalwork, to be done by hand, where I do mark out in the traditional way. If the marking out is done correctly there's no problem in aligning the centre punch by feel as it "picks up" the scribed lines.
                                                #385595
                                                Vic
                                                  @vic
                                                  Here’s the start of a four part video on making one. Make sure to look at the other three.
                                                  JC54
                                                    @jc54
                                                    Can anyone tell me what issue of MEW the article on making an Optical Centre Punch appears please?
                                                    #385727
                                                      25 and 194. For future if you need to find anything try this index
