Oil wick
Oil wick
Home Forums General Questions Oil wick
Viewing 10 posts - 26 through 35 (of 35 total)
  • #619227
    Dell
      @dell
      That’s a handy link Michael but why would felt be better than cotton braid?
      A friend that has done his 17/50 has some left so he is sending me some , it looks like candle wick.
      many thanks for all the replies and helpful links.
      Dell
        Posted by Dell on 31/10/2022 07:51:45:
        It’s probably debatable [which is good, because that’s what forums are for] … but I would assume that felt provides stronger capillary action than braid.
        That said: I am not entirely convinced by Google’s translation dont know
        … Is there a fluent French-speaker in the house ?
        DeepL produces these, for the two French texts:
        Detail of the two wicks of braided cotton which make the oil rise towards the bearings:
        Replacement of the cotton braids with felt wicks, which are better suited to the rise of the oil in the bearings:
        Edited By Michael Gilligan on 31/10/2022 08:38:35
        #619259
        duncan webster 1
          @duncanwebster1
          Locomotive axle boxes use felt sat in a tray of oil and rubbing on the underside of the axle
          #619260
          Bazyle
            @bazyle
            Horses for courses. I think felt being so thick would (in times past) have got gummed up by oil decomposing, collecting dust from open topped containers etc. There would need to be a balance between thickness of the oil used and density of the wick to get the right flow rate. Machinery manufacturers would have the time to experiment to find what suits their production line, The best an amateur can do is try something and be prepared to change it.
            #619264
              Good logic, Bazyle yes
              Most likely the ‘best’ wick for any individual lathe will depend upon the oil it uses.
              Dell
                @dell
                Well headstock all stripped out and Sod’s law the wicks were fine but new going in anyway because there is no way I could get the old wicks back in, also very negligible wear on bearings or spindle, just waiting for new wick to arrive.
                Edited By Dell on 31/10/2022 15:58:33
                #619280
                Harry Wilkes
                  @harrywilkes58467
                  I use Worsted wool on my 3" Burrell works OK for me I picked it up at the local knitting shop the wife use's
                  H
                  #619642
                  Dell
                    @dell
                    Managed to get hold of some original wick, what a fiddly job to fit without pinching or cutting it when fitting the bushes but got there in the end and I know it’s not jammed because I could slide the wick either way before I cut it.
                    Dell
                    #619643
                    Dell
                      @dell
                      749e9447-12df-4f18-8e84-2b9a9f8c0b3e.jpegForgot to add pictures 02313fd8-313b-4a70-9af2-a6d8e256170c.jpeg
                      #619658
                        Nicely done, Dell
                        … big sigh of relief ?
