odd thread
odd thread
Home Forums General Questions odd thread
  • #26528
    Philip Burley
      @philipburley44197
      Philip Burley
        @philipburley44197
        I am having problems with a fine thread , the dia is 0.156 inch ie 5/32 The pitch fits on my metric gauge marked as 50 , which I assume is 0.5 mm pitch, but seems finer than that , too fine to count till I borrow grandsons microscope . The screw is an adjuster in a model aeroplane engine ,
        any thoughts ?
        #403328
        Ian P
          @ianp
          Rather than trying to count the threads to find the pitch, Just measure haw far the adjuster travels over say, 10 turns. Simplest is with digital calipers because you can set zero over the whole assembly (exposed end of screw to opposite side of engine or carb.
          No requirement for the manufacturer to use a standard thread size (although they probably did) but establishing the pitch accurately will give you the answer.
          Ian P
          #403329
          Lambton
            @lambton
            Philip,
            0.156"= 4.0 mm
            4.0 mm diameter X 0.5mm pitch is a standard metric Fine thread. Yes it will look very fine.
            I find it is best to avoid any confusion by sticking to either imperial or metric dimensions.
            Best regards
            Eric
            #403331
            Hopper
              @hopper
              Or could it be 5/32 x 50tpi?
              What make, vintage and country of origin model airplane engine is it?
              Might give a clue as to whether it could be metric or imperial.
              #403333
                Yep M4 x 0.4 is standard needle thread, I had to buy a suitable tap when I used an OS needle on the carb I made for my Firefly
                #403361
                Philip Burley
                  @philipburley44197
                  hello Jason yes its for a old Bluebird 45 engine , the needle valve . I have one for a pattern . I was told by an "expert" that it would be an AF , I could have a try on the lathe but sure to need a die to make a clean finish
                  Thanks every one for information
                  #404364
                  Philip Burley
                    @philipburley44197
                    made one , and it works !!! amazing !!
                    #404374
                    Jon Lawes
                      @jonlawes51698
                      Well done Philip
