Not unexpected, but is it predictable ?
Home Forums 3D Printers and 3D Printing Not unexpected, but is it predictable ?
  • This topic has 39 replies, 11 voices, and was last updated 28 May 2025 at 06:44 by Michael Gilligan.
Viewing 15 posts - 26 through 40 (of 40 total)
  • #798788
      Yes … I am both embarrassed and happy !!
      I have no idea how it happened, but the troublesome .3MF file is much larger than the others in the set …
      Why ?
      Because it contains five instances of the same object, all co-located
      I deleted four and re-sliced it … after which, it printed nicely
      🙂 MichaelG
      Alan Wood 4
        @alanwood4
        Another recommendation Michael.
        “3D Printing Failures” (2022 edition) by Sean Aranda.  A bit pricey but has saved me many times from too much hair loss.
        #798815
        Alan Wood 4
          @alanwood4
          Forgot to say that there will be a tick box somewhere in the slicer setup that will cause a new version of the slicer app to open each time you send something to print.  It stops the co-location of objects but leads to the frustration of lots of windows open.  You pays your money etc
          #798831
            Thanks for your continuing advice, Alan
            Keep it coming … this geriatric dog needs to learn a lot of new tricks.
            Meanwhile, I have at last produced my set of tubular samples, which will be measured in due course.
            … the simple idea being to to investigate how the printer handles dimensions that are  seemingly impossible to print with a 0.4mm nozzle.
            Andrew Entwistle
              @andrewentwistle
              Hi Michael, for dialing in performance when using a new filament type I print a 20mm cube with the slicer set for single outer wall, no infill or top layer. I adjust the extrusion multiplier (Flow Ratio in Bambu slicer) to get exactly 0.4 mm wall width (for a 0.4 mm nozzle). A micrometer is better than calipers for assessing this.
              After building and ‘Klipperising’ my printer is set it up with the MK1 Califlower model and spreadsheet which corrected for a slight skew in xy as well as x-y scaling etc. Looks like it has been replaced with this https://vector3d.shop/products/califlower-calibration-tool-mk2
              But I guess you didn’t get the Bambu to have the printer itself as the project as I did.
              Andrew.
              #798911
                Quite right, Andrew … using a 3D Printer has been on my “bucket-list” for a long time and, quite frankly, I chose the Bambu on the basis that Vita brevis !
                I am most grateful for your helpful observations though.
                #799063
                Andrew Entwistle
                  @andrewentwistle
                  I ordered an X1Carbon last year for work and I still see Bambu as the best choice for ‘just working’. The one enhancement we made was to buy a polyurea build plate, which is sticky for PLA 45C, so removing the need to open the door for PLA prints. It reduced/removed warping in PLA. There are many options but I think this is the one we got:
                  https://www.aliexpress.com/item/1005007189059119.html
                  #799230
                    I’m not sure how best to interpret this, so I will just share the raw data for a start
                    All the test pieces have a decent finish with only slight surface texture
                    There is probably some slight ovality, but I have not attempted to measure it
                    Each value represents just one measurement with a digital caliper
                    … therefore please don’t take the implied accuracy too seriously.
                    Posture
                    The crucial point, of course, is that the 0.4 nozzle cannot produce very thin walls … and my test was done to see how the printer worked-around that impossible task.
                    Excuse the colour-cast:
                    IMG_0804
                    #799235
                    Tony Pratt 1
                      @tonypratt1
                      I can’t see any images?
                      Tony
                      #799237
                        Tony
                        I might soon give-up trying to post images on this forum.
                          < sigh >
                          Here [hopefully] is a downsized version of the previously submitted image:
                          Posture
                          Just to show the nice tidy layers.
                            That one shows up OK as for the rest the thread title seems quite appropriate!
                            #799305
                              Thanks, Jason
                              rjenkinsgb
                                @rjenkinsgb
                                For mechanical / engineering parts, have a look at Designspark Mechanical. That’s a free program which can export to .stl (though change the option to high quality as soon as you install it).
                                I find it far better and easier to use that Freecad or the other CAD programs I have, when creating 3D designs for printing.
                                You can get it via the RS Components web site.
                                #800057
                                  On rjenkinsgb Said:
                                  For mechanical / engineering parts, have a look at Designspark Mechanical. […] You can get it via the RS Components web site.
                                  Thanks for the recommendation … I will
