Hi Steve
Apologies – I completely misread your post (and the one following). My comments below apply to the MK1 clutch fitted to a Super 7, not yours. You may however, find the link of interest. I presume you will NOT need to lubricate the moped brake type clutch.
If you copy and paste the following link into your browser, you'll get details of part of the clutch mechanism.
http://www.lathes.co.uk/myfordrebuild/www.onepoint6.co.uk/Myford/Countershaft_and_Clutch.htm
Don't worry about the text as he is rebuilding an ML7. The main part of your clutch is inside the cone pulley (sadly, not shown) and is activated by the bits in the first picture in the link.
The clutch is basically a spring clip (like you'd put onto a shaft and which fits in a groove), but is around 20mm thick. The ends get pushed apart by the clutch push-rod and causes the outer diamerer to engage with the inside of the cone pulley.
Lubricate it (oil only and fairly sparingly) via the nipple in the cone pulley.
The only thing you might need to do is adjust the push rod (through the hole in the pulley, should the clutch slip. Mine was adjusted the once and has been OK since (touch wood).
Spares are no longer available for this clutch, so if it breaks you are in trouble. You can apparently fit one of the newer Myford clutches (it would be interesting for someone who has done this to provide comment re difficulty, etc.). I recently bought a little used Mk1 clutch complete, on fleabay for £90 – just in case.
Hope this helps.
Regards Tom
Edited By Tomfilery on 20/08/2013 16:45:24
Edited By Tomfilery on 20/08/2013 16:45:47
