Karl,
Worth looking at well known internet auction sites for change gears or sets of, usually cheaper than the supplier.
Nothing much wrong with the quality of stuff from the current custodians of the Myford 'badge', or their generic counterparts. However, you will pay a premium for ' badged' parts so you have to be choosy in what you want and ask if you can source for other places, make or adapt any accessories.
For example, I have used 3d printed PLA change gear set on an EW lathe (admittedly a small lathe) and individual ones (like 63)on the Myford. In fact I see no reason why you couldn't make and utilise a whole set of printed gears. obviously if you happen to be screw cutting all of the time there might be a longevity issue! There may also be an argument to have metal gears for your main x feed if you use that a lot but you will be surprised how tough printed gears can be, even in basic PLA (don't let them get too warm though!).
Even if you are the kind of animal that crashes carriages and regularly strips gears so what- just print yourself more gears for pennies and carry on stripping and crashing!
Alternatively, if you don't have a 3d printer, check out your local commercial printers and ask how much to print you a set in polycarbonate/nylon/acetal.
